Engine light - Defender Source
Old December 11th, 2015, 10:27 AM
Avahdani's Avatar
Avahdani
Nushi
NONE
Engine light
Hello friends,
Engine light is on and I can't find what is wrong. The truck drives strong and all fluids are perfect, can't seem to find an issue. It's a 97 sw by the way. Any help is appreciate it.
Old December 11th, 2015, 10:30 AM
fruitpunch
Marc Brouwer
66 IIa 88 Perkins powered
my first advice to anyone with OBD 2 plug is get yourself a WIFI or BT scanner and read the codes out with your phone / tablet. then posting the codes the advice will be much better
Old December 11th, 2015, 10:48 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by Avahdani View Post
Hello friends,
do you drive it at operating temps on a regular basis? using these truck more often helps. mine is a daily driver and I've had no problems for 12 year/120K miles other than an o2 sensor burn out.
Old December 11th, 2015, 10:58 AM
Avahdani's Avatar
Avahdani
Nushi
NONE
I drive it every day and just had it serviced at Fouroaks month ago. Unfortunately, Larry at four oaks is retired and closed his shop
Old December 11th, 2015, 11:08 AM
1of40's Avatar
1of40
1of40
Is it check engine or service engine light?
Old December 11th, 2015, 12:25 PM
Avahdani's Avatar
Avahdani
Nushi
NONE
Check engine
Old December 11th, 2015, 12:27 PM
Do these models not have the onboard code display box?
If not, an OBD scan tool to look at the codes. No help can be provided until the code(s) are known.
Old December 11th, 2015, 12:39 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Avahdani, a local auto parts store will probably have a code reader that you can borrow to read the codes on their premises and will also likely be willing to show you how to do it the first time. You can return the favor by buying a code reader from them.
Old December 11th, 2015, 01:21 PM
Departing90
Sasha
95 D90
Your local auto zone will read the codes for free. Every code is suppose to identify a particular issue. Often times depending on the code, codes are just a clue as to whats wrong & not what the actual code is referring to!!
A tech familiar with vacuum setup / sensors will be able to translate the code after an inspection.
Generally speaking if your truck is running ok as in no noises, smoke, performance loss etc. Its most prob something simple as in a cracked vaccume line / oxygen sensor etc...
Old December 11th, 2015, 05:22 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Originally Posted by Red90 View Post
Do these models not have the onboard code display box? If not, an OBD scan tool to look at the codes. No help can be provided until the code(s) are known.
the 97s have OBD2 so no box
Jimmy Buffett
Old December 12th, 2015, 01:01 AM
Avahdani's Avatar
Avahdani
Nushi
NONE
Thank you all
Reverse light / fog light gremlins tim Defender Technical Discussions 10 November 1st, 2014 11:26 PM
Glow Plug Light turn on when dome light is switch is flipped on Elbee Defender Technical Discussions 4 September 9th, 2014 06:27 PM
WTB - Defender Third Brake Light Bar w/light paydan Wanted 0 December 1st, 2011 02:28 PM
New ROW backup light and Fog light dave_lucas For Sale - Parts 2 June 2nd, 2010 07:38 PM
Rusty soft top third brake light bar and light evilfij Wanted 2 May 20th, 2009 11:26 AM
