Engine light - Defender Source
Old October 2nd, 2009, 09:30 PM
floatflyer
Bryan Krill
'95 D90 wagon
Engine light
Just bought a '95 SW and drove it home 3000 miles. No significant problems, just a couple of annoying ones. First, the engine light came on and stayed on the whole trip. I tried to have it dignosed in Arizona with no luck. When the cover was off the right seat box we noticed a modular plug not was not connected. The plug is white in color and has three pins in a triangular pattern. I did not connect the plug for all the obvious reasons. Any help here would be greatly appreciated. The other nagging problem I had was a grating grinding noise that developed when I backed off the trottle in fifth gear on downgrades. My thought was a CV joint going, but not sure. Thanks in advance for any help.
Bryan
Old October 2nd, 2009, 09:37 PM
Bryan
COngrats on your new Land Rover. I had the growl you mention when I put a OME suspension on my truck, rear links with spacers cured my problem temporarily. How many miles on your truck?
Old October 2nd, 2009, 10:12 PM
floatflyer
Bryan Krill
'95 D90 wagon
Thats' interesting, this truck has OME shocks and springs. Currently has 87,000 miles.
Old October 2nd, 2009, 10:25 PM
Was it the Service Engine or the Check engine? The Red Service Engine is controlled up by mileage.
Could it be a U-joint going bad, a diff the needs a bit more 90 WT or putting Redline in the gear box?
Old October 2nd, 2009, 10:29 PM
floatflyer
Bryan Krill
'95 D90 wagon
Check engine light comes on. The u joints were all just reolaced before sale. I'll check the diffs and the gear box oil.
Old October 3rd, 2009, 03:48 AM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
Being a 95 it has OBD I. Do you have a LED display box under the passenger seat? It should be about the size of a pack of cigarettes. If so, there should be a number lit up that corresponds to the problem that the ECU thinks it is having. If the truck ran fine, it could have been an intermittent issue.If so, disconnecting the battery will clear the CEL.
engine, ht
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
check engine light. FREEDOM Defender Technical Discussions 14 May 31st, 2005 01:10 PM
Defender Check/Serive Engine Light - help! B-Kerr Defender Technical Discussions 8 May 9th, 2005 08:32 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
