Engine knock - Defender Source
Old December 8th, 2013, 04:19 PM
hotroddef90's Avatar
hotroddef90
Rod Renfrow
1995 Defender 90 ST
Engine knock
I am having an issue with some engine knock. Seems to be mostly upon acceleration from 1400rpm to 1900rpms. At about 2000 it goes away and crusing around there is no knock until I stop and accelerate again.
I would appreciate any ideas of what it may be?
Old December 8th, 2013, 04:48 PM
Did you look at the vacuum advance hose to see if it leaks?
Old December 8th, 2013, 04:54 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Do you have any reason to rule out an exhaust leak from the manifold or manifold to Y-Pipe connection?
Old December 8th, 2013, 05:48 PM
robisonservice
John Robison
2008 Supercharged Range Rover
Noise on acceleration may be from worn piston skirts. It might also be catalyst rattle. I'd certainly put the truck on a lift ands check that first. Rocker shaft rattle tends to be independent of throttle.
To check, try pulling plug wires one at a time as you gun the motor. If one wire (pulled) eliminates the rap you have found your noisy cylinder and you know its an internal problem.
Old December 8th, 2013, 06:25 PM
hotroddef90
Rod Renfrow
1995 Defender 90 ST
Thank you for the advice.
I haven't checked any of that but I will.
Thanks again,
Old March 17th, 2014, 03:57 PM
hotroddef90
Rod Renfrow
1995 Defender 90 ST
It was the catalytic converters after all.
Engine Knock devinchi Defender Technical Discussions 3 January 19th, 2010 10:38 PM
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
