Engine Knock - Defender Source
Old January 19th, 2010, 10:13 PM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
Engine Knock
My D90 sat unloved for a while, and lost it's oil pump prime. I got the pump re-primed, and have oil pressure again (the oil light turns off). I unfortunately have a knock in my engine now. A mechanic friend told me that it was not a problem, and I should let it run and the knock would go away in a while (he said it could be 20-30min). Because of the knock I have tried not to run it, and it hasn't been running for more than a minute or so at a time.
What's the consensus? Is my buddy right?
I got your JEEP thing, now it hurts when I pee!!
Old January 19th, 2010, 10:23 PM
Knock or tick? How long did you run it without oil pressure?
Old January 19th, 2010, 10:37 PM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
It idled about 10min w/o pressure. I guess the noise is more of a tick, but a good solid tick.
Old January 19th, 2010, 10:38 PM
Tick I would suspect rockers. Personally, I would run it until it dies, but it is easy enough to check the rockers. Sometimes they do get better after running for a bit.
PS I got a 3.9 long block here if it really is toast (which I highly doubt)
engine
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
