Engine dying when coming to a stop?? - Defender Source
Old November 15th, 2007, 08:16 PM
durangorover
Chris Wherry
1995 D-90
Any help on this would be much appreciated. My 95 D-90 is dying when I come up to stops. It seems to happen randomly no mater if the engine is hot or cold. I'm not the best with engines so I don't know where to start. Here is my guess though. Fuel filter? Fuel pump? O2 sensor? Thanks, Chris
Old November 15th, 2007, 08:26 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
throttle position sensor perhaps?
could be alot of things. Does it run fine most of the time? does it start right back up every time? does it just skip past idle and die, or does it sound like its trying to hold on?
the more info you give the better chance of narrowing the culprit down.,
~Steve
Old November 15th, 2007, 08:57 PM
my vote is the idle air valve or idle choke bypass inlet is gunked up.
Old November 15th, 2007, 11:27 PM
durangorover
Chris Wherry
1995 D-90
Steve,
It does run fine most of the time but I think your on to something cause it does just skip past idle and die. Sometimes it tries to hold on for a few seconds and then dies. It also starts right back up and runs normal. It's so quite when it dies I don't even realize that it's dead. Hope this helps. Thanks
Old November 15th, 2007, 11:28 PM
Ecu?
Old November 15th, 2007, 11:32 PM
Stepper Motor is the first step. Then Throttle position sensor (you can test this before replacing the stepper motor otherwise known as the idle air control valve).
Do you get any codes from the ECU? Is the ECU wet? How old is the cap/rotor/wires? How old are the O2 sensors.
Old November 15th, 2007, 11:50 PM
durangorover
Chris Wherry
1995 D-90
There is no code on the ecu. I don't think the ecu has been wet. I got the truck in July and as far as I know none of the things you have mentioned have ever been touched. The truck has 60k miles on it now. Thanks
Old November 16th, 2007, 01:47 AM
I would take out the stepper motor and clean it as a first step. The check the TPS by hooking it up to a multimeter and making sure it does not jump. Then replace the stepper motor. If you do not know when the plugs/cap/rotor/wires were replaced, they should be replaced now (they are part of the 60k service).
If none of this works, you are down to the unusual suspects. O2 sensors, a bad alternator, a bad ECU, and plausibly even some other senors could cause this.
Old November 16th, 2007, 12:10 PM
durangorover
Chris Wherry
1995 D-90
Ron,
Thanks for the help. I'll look into all of it. My education on motors has now begun. Thanks again.
Old November 16th, 2007, 12:33 PM
Grover's Avatar
Grover
Thumbs up
My truck was idling funny...cleaned the stepper motor and the crank case vent/wire mesh with 3M carb cleaner...problem soved...
Good Luck...
Old November 16th, 2007, 05:42 PM
azD90's Avatar
azD90
Kevin Houseal
1994/D90
Mine did this for a year off 'n on, cleaned stepper and it's been fine. -cheap fix, got lucky.
Old November 17th, 2007, 11:12 AM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
Where is the idle choke bypass inlet???
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old November 17th, 2007, 04:34 PM
durangorover
Chris Wherry
1995 D-90
One more question for you guys. When you say clean your stepper motor, what exactly do you use to do that?
Old January 22nd, 2008, 08:23 PM
Where is the throttle position sensor located on the 95? Carb cleaner should work fine for cleaning the stepper motor
Old January 22nd, 2008, 11:14 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Mine does the same stuff ever other month for a day. It acts like it has bad gas. I havent messed with it since it is getting a new power plant soon. Please keep us posted on the solution please.
And hay
And I love you too
engine
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
