Engine dies while underway - Defender Source
Old June 13th, 2013, 01:07 AM
gaffib
Bill Gaffi
1997/D90
Question Engine dies while underway
Had 97 D90 speedometer drop to zero and engine die while underway. Took it in and speed sensor was replaced. Made it home then it wouldn't start so I replaced ignition switch. Ran for a few days then it died again. Dealer put another ignition switch in. The wires at the ignitions switch had been very hot. Ran for a couple weeks and today engine cut out for several seconds, came back and ran fine since for about an hour. Asked the dealer if they put dialectric grease on connections and they said yes. They don't seem to know where to look now. Any ideas about what is wrong or who to take it to in the Portland Oregon area other than Land Rover Portland?
Old June 13th, 2013, 02:19 AM
Couple of friends had fuel issues recently. Kinda shocking that dealer mechanics don't know to test fuel line pressure.
Old June 13th, 2013, 07:49 AM
Lol. Seriously?
Mechanics are compensated by cramming as many 'by the book' hours into a working day. By definition they are paid to cut corners.
Old June 13th, 2013, 09:34 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Did the tach cut out or just the speedometer?
Old June 13th, 2013, 09:54 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Does the dash go completely dead like the ignition switch was shut off? When it cut out today, did it just stumble but stay running or did you have to restart it. Did the speedometer drop to zero when this happened? Is anything else, like the radio or gauges, affected when this happens? basically looking to determine if it's a power supply issue or an engine management issue. I'd look at the fuse boxes for loose connections & corrosion, look at the engine main relay, battery connections. Does this truck have a battery cut off switch? if so, temporarily bypass it. What about aftermarket electrical accessories? I'd carefully inspect any added wiring, especially anything connected to a green wire (ignition power).
You might also look at the crank position sensor. Without a CPS sensor signal, the ECU won't fire the injectors or the ignition system. It would be helpful to be able to check for spark/fuel when it is acting up.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old June 13th, 2013, 10:00 AM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
I had a similar thing happen but on my 95 D90. And after replacing some stuff, gave up and went to the dealer. They replaced a ground cable on the TC and all was fixed except my red face!
"I think you need a little weatherstripping - right here..."
engine
Occasional Hard To Start and Now The Engine Spontaneously Dies artpeck Defender Technical Discussions 3 June 23rd, 2009 09:49 PM
Engine Dies: Fuel Pump & ECU Relays? jimngo Defender Technical Discussions 4 October 15th, 2006 01:25 PM
engine dies going downhill?? P1CR Defender Technical Discussions 1 April 16th, 2004 04:08 PM
