Engine degreaser.. - Defender Source
Old May 24th, 2006, 07:22 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Engine degreaser..
I am changing the seal on my oil pan and one of my valve covers and i was wondering if there are any bad things that might happen from spraying engine degreaser in the pan or on the valves.. I'm trying to keep it out but some is getting in no matter what.
Old May 24th, 2006, 09:15 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Can't help you with that, but I've been using por-15's marine clean on another project, and it's by far the best degreaser I've ever used.
Old May 24th, 2006, 11:11 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The biggest thing to remember when cleaning things around an open engine, is that degreasers can dislodge sludge that can block the oil passages in the engine. Sometimes with older engines, the use of degreasers in open oil galleys, or oil "cleaners"/high detergent oils, can break loose slime and grime that can't make it through the galleys and you then blow bearings and such. So, it is in getting on the valves, I would consider not using it there. If it is only on the valve cover away from the engine, then don't worry--just put it back on clean. I always final clean my parts with brake cleaner. Actually, that is almost always what I clean with----
engine
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
used winch now engine runs weird cpk Defender Technical Discussions 6 March 5th, 2006 04:03 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
