Engine Crane - Defender Source
Old July 10th, 2016, 04:06 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Engine Crane
Looking for any feedback on foldable engine cranes.
In the middle of a house move so need to move a couple of engines and transmission onto a trailer and then off at the other end. An engine swap on the books shortly also.
Issue is, much of the online feedback shows that most cheap CAD$400 cranes are dodgy, with bolts and hydraulic pumps failing. I guess it would be the answer to change out to grade 8 or structural fasteners and pins. Maybe install a decent cylinder.
Would love to buy a locally manufactured one, but at close to CAD$5000 for a Hein-Werner unfortunately I cannot justify it.
Eric.
Old July 10th, 2016, 04:49 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
For $180, it works fine.
Old July 10th, 2016, 04:53 PM
phoenix37's Avatar
phoenix37
john
x2... I pulled my 3.5 v8 and t95 trans (think big and heavy) in one lump with this same crane.
Old July 10th, 2016, 06:09 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
I have the same one (only from Summit Racing....for more money). The throw is long enough for trucks, and I lifted the engine, trans, and transfer case at once. Also used it to hold the engine while I pressure washed it prior to disassembly.
Angus
Old July 10th, 2016, 06:45 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Also have a HF. It's like $6 shipping direct to your house.
I pulled one of Raub's favorite motors out with the tranny and TC attached and put it in a 200Tdi, tranny and TC all bolted together - no issues.
Old July 10th, 2016, 07:05 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
I have a 2 ton Pittsburgh Automotive / Harbor Freight job. Works great! Even has enough oomph to comfortably pull the 300tdi+R380+xfer case all in one giant lump.
2 ton Capacity Foldable Shop Crane
A+++ will buy again (when it eventually fails).
Old July 11th, 2016, 06:10 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I was in a pinch once and rented a crane for like $12/day. It was super heavy duty so just a thought.
Old July 11th, 2016, 10:45 AM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Thanks guys. I will see if the Pittbburg/HB is available up here as shipping costs over the wall to Canada are crazy. If not, will just buy another cheapo and see how it goes.
Eric.
Old July 11th, 2016, 10:56 AM
Naplm00
M
Another vote for the 2ton. Nice thing about the larger capacity is that you can have the load out further on the crane... Great for lifted trucks and pulling engine/tcase/Trans together.
The 1ton will have half the weight capacity at the furthest point out on the crane.
I had the hf 2 ton folding for about 6 years, sold it when I sold my place... Never failed me... Seen here with a fresh 200tdi on a load leveler
Old July 11th, 2016, 11:05 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
HF
Another vote for the HF one, hard to beat on a RoI basis for occasional use. Although I did replace a few of the key fasteners w/ higher strength metric bolts.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
engine
Without an engine crane, life would cease to exist... o2batsea Defender Technical Discussions 12 February 16th, 2012 02:18 PM
service engine VS. check engine scubadanster Defender Technical Discussions 18 June 23rd, 2009 10:18 AM
Engine Oil Pouring from engine dfscott Defender Technical Discussions 46 June 18th, 2007 08:45 AM
RPI cam or Crane pro's & cons Bowtracer Defender Technical Discussions 1 March 4th, 2005 04:00 PM
Crane Cams--are they available? Davis Defender Technical Discussions 9 June 7th, 2004 06:17 PM
