engine conversion for Disco 2 - Defender Source
Old May 19th, 2005, 10:08 PM
asator
Thor Jonsson
I need a new engine for my 2000 Disco 2 and I would like to drop in a 4.6L. Will any of the 4.6L fit? Is the Range Rover 4.6 the same as the 2004 Disco 4.6? What are the issues of a conversion?
Old May 20th, 2005, 08:54 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The only issues you will need to be concerned with are with the heads and if they have the secondary air or not. The rest is a straight drop in as long as you use the same type front cover and reuse your air/fuel management. In otherwords, no issues if using a short block, possible head issues if using a long block, and coordination issues on air/fuel if using a complete engine with different engine management.
conversion, disco, engine
1962 IIA SWB with Robert Davis Engine Conversion Jack Straw For Sale - Vehicles 1 April 12th, 2007 01:53 PM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
