Engine code 44 - repeatedly fires - Defender Source
Old October 30th, 2014, 01:20 AM
sro
Sam Odio
2008 LR2
I've repeatedly gotten code 44 ... I think this is the third time it's been triggered over the last year or two.
Each time I replace the o2 sensor and the code goes away...for a while.
Does anyone know if there might be some other issue that is triggering the malfunction? I noticed one of the bolts on the exhaust manifold was loose...perhaps that was part of the issue.
Old November 1st, 2014, 01:39 PM
carlosz's Avatar
carlosz
Carlos
methodical steps, first of all make sure you don't have oil leaks or any other foreign material on the top of the sensor, then inspect your connections. correct if needed, then hook a scanner to it and map the sensors it is the only way to really verify what is going on.
Old November 1st, 2014, 03:45 PM
Exhaust leak would cause it too.
Old November 1st, 2014, 05:06 PM
carlosz's Avatar
carlosz
Carlos
How right you are, pre sensor exhaust leak causes false air readings which do not jive with engine function, thus the code is set as well.
the truck ran like a "raped ape"
A fussy warm weather creature...
engine, fire
Oil lines and fires ECR Defender Technical Discussions 79 May 19th, 2012 03:09 PM
Oil line fires ECR Misc. Chit-Chat 12 November 29th, 2008 08:37 AM
Victim of the Malibu fires oldscratchggf Misc. Chit-Chat 6 December 9th, 2007 05:00 PM
Should LR Address these Engine Fires Ragland Defender Technical Discussions 49 December 13th, 2005 01:21 PM
Repeatedly blowing undehood 30A fuse Hans Defender Technical Discussions 1 September 6th, 2005 04:24 PM
