Engine - Chassis swap in California - Defender Source
Old February 24th, 2017, 12:46 AM
Socal
M
Hi has anyone done an engine swap and or a chassis swap on their defender in California? If so do you need to inform the DMV? Can anyone share their experiences...
M
Old February 24th, 2017, 01:00 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
M
You technically can't do a chassis swap on a defender in California. The identity of the vehicle is determined by the frame. Once you change the frame you've changed the identity of the vehicle. You can contact your local CHP office and talk to the vin officer if you have questions.
engine
Galv chassis swap classic4x4 Defender Technical Discussions 8 January 15th, 2017 05:06 AM
Chassis swap DailyDrivenDefende Defender Technical Discussions 8 December 28th, 2015 09:22 PM
Carb rebuild vs FI swap vs engine swap samer0214 Defender Technical Discussions 14 July 13th, 2014 08:33 AM
Chassis swap questions Paul K Defender Technical Discussions 66 December 23rd, 2013 03:32 PM
Chassis /bulkhead swap DonFromWhitby Defender Technical Discussions 27 April 12th, 2013 11:09 PM
