Engine Block Heater - Defender Source
Old October 27th, 2007, 12:29 AM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
Engine Block Heater
I have a block heater to install on my 95 Defender...can anyone tell me where the freeze plug is I am supposed to put this thing? Thanks
Old October 28th, 2007, 06:56 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Is it a generic version? or is it marked for the 3.9? Definitely have to make sure it's the correct size first, as there are a few different sized plugs out there. Not sure which one it may be, but most likely it will be one of the side plugs behind the exhaust manifold.
Your profile says your currently in Charleston, is that the case? I'd consider a block heater useless in South Carolina, it's mainly when you see consistant temperatures well below freezing that you need them.
-Hans
My oil line fix
My 100k stopped odometer fix
Old October 28th, 2007, 08:28 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Actually using an engine block heater in all temperatures can reduce engine wear, emissions and deposits. The engine gets up to temperature faster - plus its really nice on a cold day to have heat coming out of your vents by the time you reach the end of your driveway...
Old October 28th, 2007, 10:07 PM
Hans's Avatar
Hans
Hans Haase
I dunno, Seen too many bust loose and dump all the coolant because of the poor quality of the heater. If I had a choice I'd go with an oil pan mat or dipstick element.
My oil line fix
Old October 28th, 2007, 10:19 PM
bjenk
Brian Jenkinson
1994 D90
I would go with engine block heater. I will look at mine. I installed one last year and it is great. I did however cover the cord with some flame resistant material. I had one melt from the exhaust on a landcruiser before.
brian
Old October 29th, 2007, 12:25 PM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
Sorry about that, I am actually in Alaska now. Temps pretty much stay below freezing from now until April or so. I'm pretty sure it is a generic version that RN sells from the 90. The part number on the package was the same as the genuine part except for the first few letters, and about 1/2 the price. So...I'll check behind the exhaust manifold. How do they come out? Thanks for the help, the instructions were pretty lame...remove plug, replace with heater, plug in.
Old October 29th, 2007, 04:20 PM
Hans's Avatar
Hans
Hans Haase
Alaska? Yeah, that's a different story, definitely need one there.
First thing to do is drain all the coolant out of course.
Usually you can get a freeze plug out by knocking one side in with a heavy punch, this will make it twist in the hole and let you grab it with big pliers or get a prybar behind it. But you have to be careful not to damage the block around the plug. They just press in to put the new one in, be careful that it is level with the hole when you do it, and that the mating surface is nice and clean.
Another option is to take it to a good mechanic, most shops up there should be familiar with them enough to do an install pretty cheap and quick. Plus they can do a flush and new anti-freeze at the same time, very important to keep the stuff in good condition up there.
Also, consider a battery blanket as well. Cranking amps drop like a rock in real low temps.
My oil line fix
engine, heater
200tdi block heater vs hose heater tomaco1 Defender Technical Discussions 14 December 7th, 2009 10:55 AM
Engine block heater Lindy Defender Technical Discussions 0 December 2nd, 2008 09:43 PM
Block sealant (was coolant gasses in rad) Davis Defender Technical Discussions 6 April 6th, 2006 01:08 AM
Engine Block Heater for Defender 110 - tips? COSteve Defender Technical Discussions 10 December 6th, 2005 01:12 PM
