Engine and/or Transmission? - Defender Source
Old March 17th, 2008, 02:49 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
This is what I have in my Forward Control 101:
2.5L NA Diesel + LT77 + LT230.
CAN I do this:
Defender 3.9L + Disco I automatic transmission + LT230
or
SHOULD I do this:
Defender 3.9L + LT77 + LT230.
Old March 17th, 2008, 03:10 PM
Probably neither because the ZF auto and LT77 V8 are both much longer than the stock 101 LT95 or the 4 banger LT77
Old March 17th, 2008, 03:13 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Are the "4 banger LT77" and the "LT 77 V8" different? It currently has an LT77 in it (probably from an early MOD 90)
Old March 17th, 2008, 03:17 PM
Yes, the V8 LT77 is much longer. 6-8in.
Old March 17th, 2008, 03:20 PM
Greg,
Using the transfercase mounts as a reference point- do you have much room for a longer engine going forward ? Seems to me since most of these came with a v8 & lt95 you should be able to fit a v8 lt77 setup in there.
Old March 17th, 2008, 03:22 PM
The 101 FC Lt95 is much shorter than the one in a 110 or Range Rover.
Old March 17th, 2008, 03:24 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Thanks for the help Ron.
So length is the issue.
But can I mate the 3.9L to the LT77 I have in the 101 now (assuming it is a 4 banger LT77).
And, can I mate the Defender 3.9L to the ZF auto from a Disco I?
Old March 17th, 2008, 03:28 PM
I think you can mate a short shaft four banger LT77 to a V8 by using a series V8 adaptor plate. If it were me, I would just source a 101 FC LT95. Roadside Rob has one I do believe. Have him regear it to range rover ratios.
Ron
Old March 17th, 2008, 03:32 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Ron
So then I would have the 3.9L + LT95 + LT230.
What would regearing it accomplish?
Old March 17th, 2008, 03:37 PM
You would have a 3.9efi to LT95. Regearing makes your highway speed better.
Old March 17th, 2008, 03:45 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I got it, the LT95 has the transfer case built-in.
Thanks for the help.
What is the status of Roadside Rob? Where is he located?
He doesn't come around these parts much anymore.
Old March 17th, 2008, 04:14 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Search Southwest Rover.com
I think you could make the auto box work without to much drama. I know I could. 4.2 would be better as well. And injected.
Or Chevy v-8 to 101 transmission. I have the adapter plate in stock. Have Rob build up his transmission/transfer case for it.
JP
legend in my own mind
Old March 17th, 2008, 04:28 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Seems like there are as many options as there are opinions.
I have access to a 3.9L so that will be the most convenient engine for me. Ultimately, I would like to run an automatic transmission and have found a ZF that is "close".
Nothing comes up for southwest rovers, the site looks like it is down.
engine, transmission
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Yet another engine fire chrisvonc Misc. Chit-Chat 80 August 30th, 2005 02:22 PM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
