Engine alternatives for RHD 1988 LR90 turbo Diesel - Defender Source
Old August 22nd, 2015, 01:17 PM
mrdoiron's Avatar
mrdoiron
mike doiron
1961 Series IIa Hybrid Defender
I am looking for suggestions for Engine alternatives for RHD 1988 LR90 turbo Diesel - the one I picked up recently needs to be rebuilt, but since it is only a 4 cyl don't really feel the cost is worth it to rebuild a 4 cyl versus finding a donor alternative.
As it is a RHD, and I'd prefer to find any Land Rover drop in alternative that could mate ok with the trans/transfer case etc, looking for both specific vehicles to search for as donors, as well as ANY available options anyone may know of (preferably close to Dallas area the better for cost on transportation).
appreciate any assistance - mrdoiron@gmail.com, 469 408-2794
thanks, mike
...mike
1961 SerIIa Hybrid Defender RHD
1969 SerIIA bugeye
1980 SerIII Lightweight ex-MOD RHD 24v
1988 LR 90 Turbo Diesel RHD
Old August 22nd, 2015, 01:22 PM
A 200TDi or a 4 cylinder LR gas engine will drop right in. Since you have a RHD a Discovery 200TDi will fit without any alterations too.
Old August 22nd, 2015, 01:38 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
^^^^What Dave said^^^^
Old August 22nd, 2015, 01:39 PM
mrdoiron's Avatar
mrdoiron
mike doiron
thanks for this... I think a 300TDI would provide more power for what I would like to get out of this in the end, just not sure availability and cost etc... ideally a small V8 would be preferred if that would mate ok.
mike
...mike
1969 SerIIA bugeye
Old August 22nd, 2015, 01:53 PM
200 vs 300 same horsepower. Just cz it has a bigger number in the name doesn't mean it is a "better" engine.
You can get a V8 in there. Lotsa people have. You'll need a bigger radiator, change the exhaust, and figure out the fuel system.
Old August 22nd, 2015, 02:10 PM
mrdoiron's Avatar
mrdoiron
mike doiron
Thanks Bill,
In terms of V8 alternatives (land rover), and recommendations on easiest donor vehicles to try and source this without breaking the bank ? Like an older Disco ?>
...mike
1969 SerIIA bugeye
Old August 22nd, 2015, 02:20 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Mine had a 3.5 Twin carb V8 when I got iy. Put a 3.9 Efi & auto trans in from a Discovery 1.
Much better!
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old August 22nd, 2015, 02:22 PM
You said drop in with no changes to gearbox.... The 200TDI is the only Rover option. You can also do the Mercedes engine with Mr. Davis adapter kit.
300 TDI, V8, etc.. all require modifications in order to install.
Old August 22nd, 2015, 02:24 PM
And new engine mounts and different gearbox.
The Rover V8 is not much of an upgrade. Crappy power, poor reliability, horrid mileage. If going to all that trouble put in a real engine...
Old August 22nd, 2015, 02:26 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
I might add (Thanks John) that I think you can mate the 3.9 V8i to the LT77 transmission that mine had originally. I also upgraded to the 1.2 transfer case, for higher gearing.
Just don't be tempted by the 4.6. I had two, both failed.
FWIW, ECR did a Ford 5.0 conversion, but it only fits into a RHD rig. If I were to do it all over again, I'd go that route.
Old August 22nd, 2015, 02:32 PM
The diesel and V8 LT77 are different. You need change the input shaft and bellhpusing requiring a complete rebuild. The V8s also used the later version that is stronger with better gearing.
Old August 22nd, 2015, 02:53 PM
globallandrovers's Avatar
globallandrovers
Julian Kotting
1999 P38 DT, 1997 LHD 110 CSW
Location: Hertford UK, Wilmington, NC, Austin, TX and OH
We can supply 200tdi, 300tdi & TD5 kits for land rover defenders.
We also supply the short shaft R380, for use with 200tdi engines.
GLOBALLANDROVERS - Home
ID:	127748   Click image for larger version
ID:	127750   Click image for larger version
Land Rover Defender Specialist. - We ship worldwide.
We are a specialist in TDI re-power conversions, and Crate 'turn key' Land Rover TDI and TD5 engines and Transmissions.
Old August 22nd, 2015, 08:20 PM
mrdoiron's Avatar
mrdoiron
mike doiron
Thanks again - I'd love to do a Ford 5.0 dependent on availability - and if not outrageous in price compared to say a TD5.
On the Ford option, is there any reference on that conversion anywhere ? And you mention only an option on a RHD ? The LR90 I have is a RHD, but why would the Ford only work with a RHD ?
...mike
1969 SerIIA bugeye
Old August 22nd, 2015, 08:32 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Mike:
I think it has something to do with the steering. I heard it won't fit a LHD rig. I'd get hold of ECR & see what they know- that's where I heard it. The Ford 5.0 has to be easy to find- and I think it's a good engine.
Good luck!
Paul.
phoenix37's Avatar
phoenix37
john
Ford? Search gen IV LS conversion...there is a reason LS conversions are so popular...
Old August 23rd, 2015, 12:20 AM
mrdoiron's Avatar
mrdoiron
mike doiron
I like the LS conversion option.
hopefully cheaper and not much more work than a TD5 - looking into that now thanks.
Any links to someone who ventured this path with a RHD LR90 would be greatly appreciated
...mike
1969 SerIIA bugeye
Old August 26th, 2015, 02:50 PM
mrdoiron's Avatar
mrdoiron
mike doiron
Anyone know of any links to documented conversions to an LS or the like ? Love to go this route with some advice on how to not repeat mistakes etc.
thanks, mike
...mike
1969 SerIIA bugeye
Old August 26th, 2015, 03:05 PM
As stated above, search......
http://www.defendersource.com/forum/...-ls-51290.html
http://www.defendersource.com/forum/...iii-52933.html
Old August 27th, 2015, 12:36 AM
mrdoiron's Avatar
mrdoiron
mike doiron
Thanks for that sanctimonious assistance, I'm glad you understand well the concept that forums are primarily used to save people time in searching - so appreciate the links ginger.
...mike
1969 SerIIA bugeye
Old August 27th, 2015, 12:59 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
It's quite a lengthy thread. It is much easier to point someone in the right direction than to start a new thread covering the subject.
Good luck with your conversion. They are fun.
Black Rhino Lives Matter
90, diesel, engine, rhd
1988 Rhd 110 Turbo Diesel $17k Allthingsfast For Sale - Vehicles 6 August 27th, 2014 07:02 AM
Turbo Diesel or Diesel Turbo? Paul K Misc. Chit-Chat 11 April 11th, 2013 11:59 PM
Proper 1988 Defender petrol V8 engine, runs great& complete. removed for turbo-diesel ZombieMotors For Sale - Parts 0 April 1st, 2013 12:17 PM
1984 RHD Diesel LR90 Defender 90 StphNieuw For Sale - Vehicles 47 January 26th, 2013 11:18 AM
1984 RHD Diesel LR90 Defender 90 giffenclarkott For Sale - Vehicles 35 July 3rd, 2012 10:08 PM
