End Of My Rope !!!!!!!!!!! - Page 3 - Defender Source
Old January 17th, 2008, 10:47 AM
Originally Posted by Emerson00
Sorry for the hijack, but as I'm the invisible poster anyway... it shouldn't matter much.
There it is again! Did anybody hear it? What is that noise? Weird. Must be my imagination...
Old February 4th, 2008, 07:59 PM
needsaD110's Avatar
needsaD110
Ben
97 D90 #1345
This is off topic, but I am going to destin for my SB. Won't be in the d90 though because that's a long drive to be in that thing.
Good luck with your problem, and don't take it LR mobile
2002 dodge 2500 CTD-blows some smoke
1997 LR D-90 ST
Old February 5th, 2008, 01:43 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Sounds similar to my ignition switch going bad problem. Having someone fiddle/turn the ignition key while checking the voltage (easy with a test light) at the coil can at least confirm if this is a probable cause...
Old February 5th, 2008, 12:58 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
So what was the problem? Inquiring minds want to know.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Tie rod end - metric or inch? byrdseye Defender Technical Discussions 3 October 1st, 2009 06:57 PM
The end is near Buckon37s Truck Build-up's & Restores 157 January 10th, 2005 06:16 PM
Hella Light Bar Plastic end Cap 48vphantom Wanted 0 December 19th, 2004 12:53 AM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Which synthetic rope revisited: snuffer Defender Technical Discussions 0 June 14th, 2004 07:59 PM
