Emissions Test Failure - Defender Source
Old August 19th, 2012, 12:20 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
My truck failed VA emissions test yesterday, in HC ppm at Idle and 2500 RPM
Limit is 125. Readings were 558/Idle and 185/2500
Everything else passed.
How do I fix it? Is it the cats?
Could it perhaps be because i haven't been driving the truck regularly?
Old August 19th, 2012, 01:07 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
In my experience that's an O2 sensor issue. The truck is running rich it sounds.
Semper Fi!
Old August 19th, 2012, 01:19 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
... Or cats could be not providing any benefit, do you have any idea what condition they are in? Plugs could be fouled and not burning clean, you could be losing spark energy somewhere, you could have a clogged air filter, timing could be off, coolant temp sensor for the ECU could be bad, there is a lot it could be causing high readings of unburnt HC in the tailpipe.
Old August 19th, 2012, 01:28 PM
loykd's Avatar
loykd
Ken Loy
Oddly, it hasn't had difficulty in passing the test before, and I haven't been driving it a whole lot
Old August 19th, 2012, 08:41 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If the truck hasn't been driven much you might want to go out and give it a good go. You may just have trapped excess stuff in the system. I would also do a good tune up with new filters etc. If you can find a shop that can do another test for you they may be able to help out.
Land Rover 110
Old August 19th, 2012, 10:13 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
by not alot, do you mean not at all?!? The last time I saw your truck running was around 2 years ago and we had to jump start you to get you out of the parking lot! Like others have said, check the plugs and may be worth a change. Then get in and drive it like you stole it for a while and try the inspection again...
Old August 19th, 2012, 10:51 PM
loykd's Avatar
loykd
Ken Loy
It's got mileage on it, just not a whole lot. It gets out at least once a month, sometimes every other month. Embarrassing, I know. But I still have a helluva time when I'm behind the wheel! You know what I'm talking about.
Old August 19th, 2012, 11:16 PM
Ken, do you walk everywhere or do you also drive a Prius or something? I hope it's the former .
Ps - ill be back in town next week so I'll hit you up and we can connect so I can grab that coil from you.
Old August 19th, 2012, 11:21 PM
loykd's Avatar
loykd
Ken Loy
Ken, do you walk everywhere .
I run....
Old August 19th, 2012, 11:24 PM
I run....
Checking with the judges, we would have also accepted "bicycle".
Distributer air gap ScottYates Defender Technical Discussions 7 December 15th, 2006 02:46 PM
Compression Test Results... need help interpreting them martym Defender Technical Discussions 12 March 3rd, 2005 09:46 PM
Emissions question Rod Hayward Defender Technical Discussions 5 March 2nd, 2005 03:44 PM
Dreaded Emissions Test and P1317- ABS Rough Road d90xj Defender Technical Discussions 3 October 24th, 2004 01:23 PM
Just failed an emissions test, suggestions? Hans Defender Technical Discussions 6 October 11th, 2004 12:12 AM
