Emissions - Defender Source
Old April 2nd, 2014, 12:29 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
So my truck failed the emissions test and my shop says it's probably the cats. My truck has under 60k miles on it. Isn't that kinda quick for the cats to wear out? Can the o2 sensors go bad and not trigger the idiot lights?
Old April 2nd, 2014, 12:36 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
It is 17 years old!!
Old April 2nd, 2014, 12:39 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
I haven't met a 17 year old with a bad cat yet!
Old April 2nd, 2014, 12:40 AM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
I'm going to leave that one alone....
Attributed to Shayne...
Old April 2nd, 2014, 12:44 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
BOOOOOOOOOO! But I have to agree
Old April 2nd, 2014, 12:49 AM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
I could be wrong but my understanding is that the age of a cat doesn't determine when they go bad. Running rich or lean will cause it to go bad... otherwise, mileage or physical damage to the cat's shell will also cause it to go bad.
If you have a 97, get the ODB read... is it throwing a code or did it fail the sniffer? Is "your shop" the same place that did the smog? The smog testers will have info on exactly why you failed.
Old April 2nd, 2014, 01:30 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Failed sniffer. Obd is clear. I will double check with shop to see what I failed on.
Old April 2nd, 2014, 07:40 AM
LR Max
Thomason, Max
1973 Series 3 109
I've heard that coolant can also kill the cat. So if you have a head gasket leak, that'll do it. However when that happens, the exhaust becomes clogged (so I've heard from my mechanic).
You don't have any codes or check engine lights or anything like that?
Old April 2nd, 2014, 09:22 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
as mentioned age and mileage do not determine failure.
what gases caused it to fail?
good luck with your search
Old April 2nd, 2014, 09:56 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
How long was the engine running before it was put up to the sensors? Drive around for a bit then while waiting run the engine at 2000 rpms for a couple and they should be nice and hot and then pass the emissions. How much do you drive your truck on a daily basis?
Old April 2nd, 2014, 10:13 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Provide your HC and CO readings. This will help in determining where to look.
Old April 2nd, 2014, 11:48 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I've also been told that changing your oil and filter before going in for the test will help. The logic is that there is gasoline in the oil (blow by) and this affects the test results.
Do like another has suggested, get the engine nice and hot before you go in for the test.
Old April 2nd, 2014, 11:52 AM
Canadian emission test failure??? Weird!
Old April 7th, 2014, 12:15 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Bc is pretty stringent... Close if not equal to Cali standards...
It's the NO that is over by .3
Tried again with a set of used cats and it was better but still failed (.3 is from second reading)... Had oil change less then 200 Kim's ago... And it was hot...
Old April 7th, 2014, 07:32 AM
Cats and oil have no effect on NO.
Old April 7th, 2014, 06:11 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
What does effect NO?
( alcohol...j/k)
Gray Market emissions tomaco1 Defender Technical Discussions 0 October 17th, 2007 09:11 AM
emissions bad news, good news artm Defender Technical Discussions 1 July 13th, 2007 09:59 PM
Emissions question Rod Hayward Defender Technical Discussions 5 March 2nd, 2005 03:44 PM
Dreaded Emissions Test and P1317- ABS Rough Road d90xj Defender Technical Discussions 3 October 24th, 2004 01:23 PM
Just failed an emissions test, suggestions? Hans Defender Technical Discussions 6 October 11th, 2004 12:12 AM
