Elite AC Kit Install - Defender Source
Old May 31st, 2012, 08:22 AM
I'm getting set to install a new AC kit in my RHD 90. Since my vehicle is an '84, the holes for the pipes and drain tube are not there. Does anybody have a newer RHD bulkhead with those holes in place that could measure the locations of them?
Dave
Old May 31st, 2012, 11:16 AM
Dimensions 'H' and 'W' as shown in these photos, or some other way of locating them. Thanks again for the help.
Dave
ID:	52390   Click image for larger version
Old May 31st, 2012, 01:29 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Dave,
I might be able to get the dims for you in a few days if no one else steps up from my td5 rhd bulkhead. Might not be perfect since I patched the holes but should get you close
Also tdiguy might be able to help, he gave me the lhd hole size / locations
Old May 31st, 2012, 05:41 PM
Awesomeness, thanks
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 20th, 2012, 12:05 AM
any further info on this? anyone?
thanks
D
Old June 20th, 2012, 06:45 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If I remember correctly the earlier years bulkhead could have been RHD or LHD. The two holes on the side of the fuse box recess are the same on this bulkhead as the one on the 85 I re-built. My aftermarket kit for the LHD used the hole on the right of the fusebox for the A/C hoses. It stands to figure that the hole on the left would be used for the A/C hoses for the RHD A/C? On the LHD truck the left hole was filled with a blank rubber gasket.
2 3/8 inches from the fuse box cut out to the center of the opening
1 1/4 from the top crease to the top of the hole
1 3/4 long
1 1/8 wide
Name:	Galvy Bulkhead inside.jpg
Land Rover 110
Old June 20th, 2012, 09:02 AM
DB,
Position the unit inside the truck and use a grease pencil to mark it. The gromet is huge and allows some leeway. I use a hole saw but a punchout tool would be better.
------ Follow up post added June 20th, 2012 09:05 AM ------
1 3/4 long
1 1/8 wide
Mike the Elite system is later OE (td5 and late 300) and requires a hole in the front of the floor
Old June 20th, 2012, 09:34 AM
Hey Doug
Thanks, I guess I was hoping for a ballpark measurement at least to get me started. I've tried a few sources and I think I have what I need. Grease pencil is a good idea.
Originally Posted by 130Tdi View Post
DB,
Old June 20th, 2012, 10:05 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Sorry Ren Ching,
I haven't gotten to this yet. Will ASAP
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old June 20th, 2012, 11:22 AM
Thanks!
Originally Posted by hillstrubl View Post
Sorry Ren Ching,
Old June 20th, 2012, 11:32 AM
I have the later model Elite version, but for my LHD. are they mirror image?
Old June 20th, 2012, 11:59 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I suck
It totally slipped my mind, I will see if I can get you something tonight.
Old June 20th, 2012, 01:24 PM
Capt Milks's Avatar
Capt Milks
DB,
Ha ha. shows you what I know, LOL
Land Rover 110
Old June 20th, 2012, 07:08 PM
ok dave, thanks.
Originally Posted by dave_lucas View Post
I suck
Old June 21st, 2012, 12:14 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Took the pics but having a hard time getting them to upload from my phone will try from my laptop tomorrow.
Old June 21st, 2012, 11:17 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
From my new TD5 bulkhead, I would guess everything is in the proper place since it was a new never installed bulkhead.
Better late than never I hope
A. 1.000
B. 1.750
C. 10.250
D. 7.400
E. 13.900
F. 3.900
Name:	AC small.jpg
Old June 22nd, 2012, 10:35 AM
Hooray
Thanks Dave. Not too late at all. Thanks to others that helped or offered help as well.
A. 1.000
B. 1.750
C. 10.250
D. 7.400
E. 13.900
F. 3.900
Old June 28th, 2012, 11:37 AM
Thanks again to all who helped with this, I see now that there not too many places the hole can go as the unit is pretty tight into the footwell. I basically put it hard up against the bulkhead center section and lined up the front edge of the under-dash unit with the front edge of the existing dash. It was a bitch getting the 2" pipe fitting through the hole and grommet in the firewall. So far the hardest part of the job has been getting the condensor installed, as it is not an direct fit in my older and non-standard vehicle. I ended up moving it back about 1.5 inches and tilting it a bit to clear the bonnet latch. I had to totally redo the upper brackets for the condensor. Not a big deal just alot of trips back and forth to the bench/vise/lump hammer. I'll get the compressor in and the rest of the pipes hooked up this weekend and hopefully get it wired up too. Then get it charged and maybe checked out by the pros. Just in time for the next heat wave...
Elite instructions are somewhat sparse on detail and accuracy.
Old July 8th, 2012, 08:21 PM
Old July 8th, 2012, 08:34 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Nice. So I take it the kit works as it should. Good timing too!
~2008 GTI TSI
ac, kit
300 TDi AC kit install manual michael67 Defender Technical Discussions 5 November 29th, 2010 11:56 AM
AC install confusion- a little help please aosias Defender Technical Discussions 6 January 3rd, 2010 05:18 PM
New and New Take Off Elite 300 TDI AC Kit LHD SafariHP The Vendors Loft 2 October 4th, 2009 11:27 PM
Skills needed to install AC aosias Defender Technical Discussions 5 April 26th, 2009 10:41 AM
How To install Badger Gutter Kit ??? Help TDI Guy Defender Technical Discussions 4 November 5th, 2005 05:41 PM
» Defender Registry
Clifford
samer0214
#304
TRS
Add your Defender
