Eliminate A/C compressor from serpentine 3.9? - Defender Source
Old December 28th, 2010, 09:45 AM
This happens to be a 3.9 from a 95 Disco, but I believe this is the same as a 97 D90 which has the serpentine belt.
I have no need for the A/C compressor and the workshop manual shows a belt routing diagram with and without A/C by changing the orientation of the idler pulley mount. The pictures are not exactly to scale and show the idler pulley bigger on the non A/C picture, but I am not sure if this is just poor artistry or it's actually bigger. It also makes no mention of a shorter belt size.
I'll find out sooner than later when I try it, but has anyone done this?
Old December 28th, 2010, 10:13 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Never tried it but it would be good information to know, but it seems another idler would be required to keep things going the right direction.
Another note, doesn't the 95 Disco have a distributor? Meaning 14CUX. The 97 does not, which is GEMS.
Keith
Big, Red and ... aaa Red..
Old December 28th, 2010, 10:15 AM
Yeah it's 14CUX but the engine is going into a '94 D90. I'll scan the manual page to show you what I am seeing with regards to the idler pulley.
Old December 28th, 2010, 10:40 AM
Here is the page from the manual. It looks like the top picture right now, and I want to convert to the bottom style
Old December 28th, 2010, 11:30 AM
Is this for the white 90?
Old December 28th, 2010, 11:31 AM
yes.
Old December 28th, 2010, 12:31 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Remove the a/c compressor and in stall a D2/early P38 tensioner(grooved pulley)assembly in the place of the old smooth pulley assembly. Install it clocked 180 of the old assembly and get the belt for it(napa #25-070733). I did this years ago on a few different rovers at the shop for people that didn't need the a/c anymore(buggys,ruggys,and modded rigs). It works for both GEMS and 14CUX set-ups as long as it is a serp drive set-up. Good luck.
Old December 28th, 2010, 12:36 PM
Mmh, yes I see it would need a grooved tensioner pulley... Sounds like more effort than I want to put into it to be honest - I can just leave the compressor in place
Old December 28th, 2010, 12:42 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Sure you can. It's all bolt on stuff,shit it's only one bolt you have to undo. One belt and one pulley. the mount is the same on both assemblys and there is even a hole built into the mounting surface of the old brackets(no drilling).
------ Follow up post added December 28th, 2010 01:47 PM ------
Not to hijack the thread but are you Jonathan's brother? I think Kaz and I met you years ago @ MAR. We were the only dummys roll'n on 35-37in boggers in the early 90's.
Old December 28th, 2010, 12:47 PM
No, it means buying more parts I don't have which takes time and money I'll check Will for one, but I'm not going to do it if it takes much time or money. Call me lazy, but it's fine as-is too.
------ Follow up post added December 28th, 2010 12:48 PM ------
If by Jonathan you mean Jonathan Galpin from Lutz (North Tampa) Florida then yes.
Old December 28th, 2010, 01:08 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
It shouldn't be much $$$ especially if you are using used parts. I would use a new belt(haha). 20min tops to install. That's funny...small world. I figured there could only be so many south Africans in Virginia.
Old December 28th, 2010, 01:11 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Why not use it for onboard air?
Old December 28th, 2010, 01:18 PM
I actually have this same setup in my D90 and that's the plan for it (have not done so, but the compressor has been happily there for years). However, for this particular "project" I am just interested in getting this D90 running so I can sell it, so I will not be putting anything like OBA on it. It's stock anyway. I could leave the A/C as a bonus in case the next owner wants to add A/C.
Old December 29th, 2010, 02:15 PM
In the name of research I decided to give this a try. RoverGuy is nucking futs, and had the part at my door at 11:40 am today. So during lunch I pulled the compressor and the existing tensioner and installed the replacement with the grooved pulley. It certainly looks like this will work fine with a shorter belt. Will need to make a trip to a parts store one of these days unless jefhuf is going to run by one (hint hint Jeff). Pictures show the old tensioner removed revealing another threaded hole and alignment hole on the bottom, which the pulley assembly mounts to in the 180 clocked orientation. Second picture if of replacement tensioner installed.
ID:	34336   Click image for larger version
Old December 29th, 2010, 04:04 PM
How sure are you of this part number? On napaonline.com the picture appears to be a very short belt, and it's a bit pricey.
http://www.napaonline.com/Search/Det...733_0258819870
This site has one for $17 (less than half the price), cross referencing to this napa part number
http://www.vbeltsupply.com/ecommerce/733k7.html
charles
------ Follow up post added December 29th, 2010 04:57 PM ------
I went out and took some measurements at 74.05" vs 88.67" that looks to be the right length for the slack I have. I'm going to try the cheaper belt and worse case I can make it a spare if it appears to be poor quality.
Old December 29th, 2010, 05:20 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
I'm staring at it on a rig right now. the part # is 25-070733 from Crapa! That pic is not the real belt...duh! Go down to the store and get the one that I gave ya the part # for....I only spent about three hours going through belts to find the exact one years ago. I'm try'n to save you time/headaches.
Old December 29th, 2010, 05:25 PM
Thanks Jake. The specs from vbeltsupply.com matched so I ordered from there. I'll report back once I fit it.
Old January 3rd, 2011, 07:10 PM
GYM's Avatar
GYM
Gary
97 SW
Do you have a part number for the grooved pulley by chance?
Old January 5th, 2011, 06:36 PM
The 733k7 belts look good and fit nicely. It's on the 2/3 mark on the tensioner. 2 of them cost less than one Napa one shipped.
I don't have a part number but Will Tillery can hook you up. I got a like new looking assembly (arm and pulley) for $45 shipped. But yes you only need the grooved pulley (which is slightly larger than the smooth one too).
Thanks for the help RoverChef
ID:	34548   Click image for larger version
Old April 22nd, 2017, 03:35 PM
Gary, did you happen to record the grooved pulley part number? Thinking about doing this same mod on my red 90 if I don't install the york compressor I've had on the shelf for years.
Originally Posted by pendy
I'm here for the D's
compressor
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
3.5 to 3.9 install kellymoe Defender Technical Discussions 3 February 6th, 2006 01:24 PM
3.9 to 4.6 1995 D-90 boxerhips Defender Technical Discussions 5 January 25th, 2006 07:20 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
Pulling out the A/C m.michaels Defender Technical Discussions 5 June 7th, 2004 12:01 PM
