Electronic Flasher Relay - LED Compatible. - Defender Source
Old October 22nd, 2010, 03:09 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
The Tridon EP36 12V (part 20-1037-0) available at Canadian Tire here is a plug-in replacement for the stock flasher relay and works perfectly with LED lamps all around.
The one thing I have not tested yet and likely won't be able to is because this is a 3-pin flasher and not a 4-pin the stock 'trailer' hookup may not flash with it.
What I'm doing for my trailer wiring is pulling battery power to the right rear quarter where a relay box will be fitted and activated by taps into the stock flasher wiring. This way no matter what the load pulled from the trailer socket things should remain stable on the vehicle wiring. (a singe 4-relay hella box will be left-right-brake-reverse and I'll put in another for the night-lighting) This will also mean that I can use the trailer socket as a power source for up to about 30A draw if needed, useful for work-lamps in camp etc.
Old October 22nd, 2010, 09:00 PM
Chris Vitale's Avatar
Chris Vitale
'95 D90 ST 2.8L TDi #2050
Thanks Andrew. This will meet my short-term needs to run LEDs front and rear. However, long-term, hopefully a replacement can be found without the need to modify as you so cleverly have indicated.
Thanks again for the find.
relay
Flasher Relay Part Number for 97 d90? KKilo23 Defender Technical Discussions 3 May 20th, 2010 09:45 PM
LED Flasher part number sea2sumag Defender Technical Discussions 3 June 13th, 2007 07:13 PM
Flasher Unit LED turn signals rustydefender Defender Technical Discussions 2 November 14th, 2006 09:28 PM
Relay replacement help cgalpin Defender Technical Discussions 21 April 18th, 2005 07:42 AM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
