Electrical Short - Page 2 - Defender Source
Old November 13th, 2015, 03:32 PM
atpick's Avatar
atpick
Andy
1990 110
Originally Posted by Red90 View Post
Which one? There is no symbol in the lower right.
Ok....the symbol farthest to the right on the bottom
The farthest right symbol on the bottom row (the choke symbol) is used on diesels for the glow plug indicator.
What truck is this? 1990 110? Engine?
Old November 13th, 2015, 03:37 PM
atpick's Avatar
atpick
Andy
1990 110
The farthest right symbol on the bottom row (the choke symbol) is used on diesels for the glow plug indicator. What truck is this? 1990 110? Engine?
1990 reg but 89 year model....200 tdi engine though
------ Follow up post added November 13th, 2015 02:39 PM ------
Interesting that a diesel would have a choke symbol....possible this was cannibalized from another truck?
Old November 13th, 2015, 03:41 PM
No, just Land Rover strangeness. They all were like this until the 300TDI came out.
As you have had an engine conversion, you will need to hunt down the wiring..... Good luck.... Nothing worse than PO hacked up wiring.
Old November 13th, 2015, 03:48 PM
atpick's Avatar
atpick
Andy
1990 110
No, just Land Rover strangeness. They all were like this until the 300TDI came out. As you have had an engine conversion, you will need to hunt down the wiring..... Good luck.... Nothing worse than PO hacked up wiring.
So then could it have something to do with the glow plugs then? I did just replace them today as 2 of them had shorted out
Old November 13th, 2015, 03:51 PM
Really, you need to hunt through the wiring on your own. The TDI glow plug wiring is different than the pre-tdi wiring and there is no way to know what the person that changed the engine did....
electrical
electrical short '97 NAS D-90 SW blenkush Defender Technical Discussions 1 October 30th, 2011 06:29 PM
Fuse keeps blowing (Electrical short) redrockrover Defender Technical Discussions 7 April 19th, 2010 11:45 AM
Electrical Problems Galore- Coil, MAF Sensor, Wipers, Fuel Pump, Short Heath Defender Technical Discussions 10 August 28th, 2008 05:52 PM
electrical short right side lights thewap Defender Technical Discussions 5 June 15th, 2006 12:31 PM
Electrical short with my radio ? paulb Defender Technical Discussions 4 August 11th, 2004 12:25 PM
