Electrical Power Drain - Page 2 - Defender Source
Old March 24th, 2013, 09:22 PM
Michael
Michael
Discovery 1998
I had this aluminum heat shield wrapped around my starter, and as a result of it wandering off the starter, was grounding the BIG cable to the starter. Talk about amp draw.
Old March 26th, 2013, 02:07 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
(Not defender related) mine draw was due to the window ECU on my Disco 1, thanks Trevor. Short term I used a blade-style cutoff on the negative terminal.
Few things are as irritating as trying to find a consistent current draw
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old March 26th, 2013, 03:59 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
Try finding an inconsistent current draw.
In the scheme of things these older trucks are very simple and finding current draws is straightforward (especially on Defenders). Narrow it down to the circuit, then narrow down the components in the circuit.
I spent days tracking down a 100mA draw in a 2005 Range Rover. Things get much more complicated when you have data networks linking modules together that are on separate power circuits. And even more so when you have a bastardized model year with different electrical systems designed by different manufacturers linked together by a network that there is next to no technical information available for.
That one ended up being the radio head unit staying on, but because the gateway module had failed and was "telling" it to stay on.
drain, electrical
Experiencing wierd electrical problems, engine power issues? madcowdungbeetle Defender Technical Discussions 0 May 26th, 2008 10:14 PM
Loss of power Leadfoot Defender Technical Discussions 4 January 28th, 2005 03:36 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
