Electrical Meltdown - Defender Source
Old April 18th, 2010, 11:38 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Electrical Meltdown
Yesterday something electrical went wrong. I have no headlights or gauges (speedo, temp, tack). Initially I couldn't get it started but found a way to get the ingition to work by jiggling the wires on the ignition. Driving lights, blinkers, guage lights, radio, horn, everything else seems to work. I quickly looked at the fuses and didn't see any problems. Any ideas?
Old April 18th, 2010, 12:05 PM
Lucasd2002's Avatar
Lucasd2002
David Lucas
[VACANT]
Did you check the ground connections?
Old April 18th, 2010, 07:46 PM
Reese_D90's Avatar
Reese_D90
Reese
Yes
Seems to all be connected
Old April 18th, 2010, 07:52 PM
madcowdungbeetle
Carter
I had something similiar happen on my 94. If I recall it was a bad ground in the tail lights circuit.
Old April 18th, 2010, 11:53 PM
CDeWan
Clay DeWan
5.3L beastie
Is your ignition falling apart - meaning where the key fits into. There is a backing plate that sometimes just fails and pops off. Done finito. if that happens you will need to pick up another ignition set up.
Old April 19th, 2010, 11:42 AM
Reese_D90's Avatar
Reese_D90
Reese
Found at least part of the problem. Looks like my rear hella work light wiring shorted out. Melted and in the process probably has crossed a few wires. I need to trace where all the wire runs and I will hopefully find the issue. I am thinking it is somewhere in the center console by the fuses since that's the path the PO wired the rear light from the dash switch to the battery. I'm still not sure how the ignition issue fits in. Thanks all for the suggestions.
Old April 25th, 2010, 08:27 PM
Reese_D90's Avatar
Reese_D90
Reese
Im still not able to find the source. No headlights, No gauges, No ignition to fire the starter. Any ideas on a common denominator?
thanks
Old April 25th, 2010, 09:16 PM
Do you have the RAVE Disc? Investigate the wires that were crossed and melted. Find out where they go and what they tie into.
Old April 25th, 2010, 09:44 PM
Reese_D90's Avatar
Reese_D90
Reese
Straight from the switch, out bulkhead and along frame below the truck to battery box and then to battery terminal and then to rear work light. I cant find where it might have impacted other wires.
Old April 26th, 2010, 12:46 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Not sure if this will help....I had major electrical problems and it turned out the wires in my rear harness inside the frame were worn bare up against the frame. The rear harness was pulled from the frame and three 1foot sections were replaced, solved all of my problems.
This caused a few wires in the dash to melt and all kinds of brake and light issues. Also starting problems.
electrical
Help With Electrical Gremilins mdmccallum Defender Technical Discussions 8 January 7th, 2006 01:24 AM
Electrical problem whistler110 Defender Technical Discussions 10 December 12th, 2004 12:25 PM
Electrical for beginners paulb Defender Technical Discussions 5 October 18th, 2004 01:58 PM
battery/ electrical issues steve_brooks Defender Technical Discussions 1 April 23rd, 2004 04:05 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
