Electrical issue? Turn Signal / Brake pedal - Defender Source
Old November 7th, 2012, 07:33 PM
Flagg's Avatar
Flagg
Flagg
1995 Defender 90 NAS
Guys,
I am an original owner of my D90. It did something on me tonight that I have not seen (and I thought I had seen a lot) All was working when I drove the truck earlier today.......I am pretty sure.
With Head lights on: Hit the turn signal stalk when approaching a turn. The turn signal does not come on. Leave the stalk up or down - Tap the break pedal, the turn signals come on.
If you are coming to a turn AND braking, AND hit the turn signal stalk while already braking, the signals turn on like normal.
Is this an issue with the headlights (I will find out tomorrow if it happens with the lights off)? Or a problem or short with the brake lights? The Turn Signals?
Curious if this exact thing has happened to anyone else..........I could just slightly change the way I drive and tap the brake pedal every time I use the signal It would not be the first time the Defender has made me compromise something
Flagg
Old November 7th, 2012, 07:36 PM
Sounds like you need an exorcist.
Old November 7th, 2012, 08:21 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The turn signal and the lights are on separate switches but they may share the same ground. You could pull the steering column plastic cover and look at things. Your turn signals go threw the Hazard switch before the stalk. You could check to make sure all the wires are connected to that. You will have a large plug with two separate wires, one on each side.
Land Rover 110
Old November 9th, 2012, 01:51 PM
Flagg's Avatar
Flagg
Flagg
And now it is not doing it............I will monitor........
Flagg
Old November 9th, 2012, 01:54 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
sounds like a short
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old November 9th, 2012, 02:08 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
I had a similar issue. Turned out to be a fuse that was not properly seated in the fuse block. The mail part of the fuse was between the female contact and the plastic housing. Once I reinserted the fuse into connector it worked fine.
------ Follow up post added November 9th, 2012 02:08 PM ------
Male
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
brake, electrical, signal
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Rear turn signal light tron Defender Technical Discussions 3 December 5th, 2005 11:02 AM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
