Electrical Issue - Defender Source
Old November 19th, 2011, 03:07 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Electrical Issue
I was hoping someone might know something about this. When I apply the breaks or use the turn signals my temp/gas gauges drop (ie they don't register). Once i take my foot off the breaks both gauges rise to their normal reading. However, once i'm done using the turn signal the gauges remain bottomed out and don't work properly until I turn off the 90. When using the brakes the gauges move back up when I take my foot off the pedal. I've checked all the sockets and most of the wiring and all appears to be good. I removed the flasher and tried the breaks and the gauges operate properly (and the rear brake lights do come on). So, do you think the problem is the flasher or do you think there is a short in the wiring somewhere. The turn signals do not work.
I can't get a flasher for a few hours so wanted to see if there was anything else i should check before going to the auto parts store later today.
Any help would be greatly appreciated.
------ Follow up post added November 19th, 2011 03:43 PM ------
FYI, the local auto parts store didn't have the flasher so I put it back in and everything works now.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old November 19th, 2011, 09:59 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I think you have a short somewhere. Turn on the flashers and have someone watch the gauges to see if anything changes while you jiggle the wiring. Start at the rear and trace forward through the entry point into the frame. The short could be along the harness as it passes through the frame.
Old November 20th, 2011, 03:40 AM
CDeWan
Clay DeWan
5.3L beastie
hazard
See if your Hazard button totally disengaged. Mine sometimes gets bumped but not fully engaged and
screwy things happen with the lights
Old November 20th, 2011, 01:22 PM
lordhelemt's Avatar
lordhelemt
Paul
Thanks. I think the problem is either the flasher relay or hazard switch. After unplugging/reattaching both plugs everything seems to be working fine.
electrical
Electrical Issue lordhelemt Defender Technical Discussions 1 June 26th, 2011 09:15 PM
HELP!! Weird electrical issue phoenix37 Defender Technical Discussions 18 March 20th, 2010 02:36 PM
electrical issue phunter Defender Technical Discussions 8 November 1st, 2008 08:52 PM
110 electrical issue bcourtney Defender Technical Discussions 4 August 6th, 2008 06:40 AM
Need help diagnosing electrical issue cgalpin Defender Technical Discussions 22 January 25th, 2007 08:53 PM
