Electrical Help Needed - Defender Source
Old May 30th, 2013, 07:45 PM
I picked up the 90 from the soda blaster and it wouldn't start. We push started it and drove it home.
What's Working:
Horn
Defrost blower
Headlights and Front Markers
Flashers
Glow plug indicator (Not sure if the glow plugs are heating)
Shut off valve
Whats Not Working:
Starter
Turn signals
Brake lights
Rear fog lamps
Any guesses before I start tearing things apart.
Old May 30th, 2013, 07:57 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Check your grounds
Old May 30th, 2013, 08:00 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Whats Not Working:
Starter
Turn signals
Brake lights
Rear fog lamps
Starter - separate circuit from everything else but look at the ground circuit
Lights - probably grounding issues
if they blasted inside there could be problems with the rear ground connections
also check the bulbs as static buildup and vibration can finish off bulbs that are on the brink of failure due to age
lastly look at fuses and wiring to see if anything came loose
Old May 31st, 2013, 06:20 PM
Blew out the ignition switch and the relay and it starts up fine. Still no brake lights or turn indicators. I tested the switch on the top of the master cylinder for voltage. Zero on either side, shouldn't one of the sides have 12v?
electrical
Help With Electrical Gremilins mdmccallum Defender Technical Discussions 8 January 7th, 2006 01:24 AM
Electrical for beginners paulb Defender Technical Discussions 5 October 18th, 2004 01:58 PM
manual transmission needed ember Wanted 0 August 31st, 2004 11:50 PM
battery/ electrical issues steve_brooks Defender Technical Discussions 1 April 23rd, 2004 04:05 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
