Electric window fuse? - Defender Source
Old October 4th, 2014, 06:06 PM
Breen
Breen Brunetti
1997 Defender 90
I have a 1997 Japan spec Defender 90 that came with electric windows. The passenger window won't operate and feels like switch is broke. I took switches out of dash and tried it with working driver window and it didn't work. So then I tried good switch with bad passenger window and there was a spark., now neither window will work and the driver window that was working fine is stuck halfway down. Is there a fuse for the windows? Did the switch blow somehow? I also cannot locate a replacement switch anywhere. Anyway to get the window back up ?
Old October 4th, 2014, 06:22 PM
phoenix37's Avatar
phoenix37
john
Sounds like you have a short somewhere.. You can take the door panel off and put 12v directly to the window motor to get it back up
Old October 4th, 2014, 07:05 PM
Breen
Breen Brunetti
1997 Defender 90
Thanks. I'll check out taking the door panel off. Is there a fuse that might have blown. The drivers side never had a problem until I connected the bad switch.
Old October 4th, 2014, 07:34 PM
phoenix37's Avatar
phoenix37
john
If you are getting sparks you have a short. If the fuse (I'm assuming there is one but can't say) was blown you should be getting no power to the switch so no spark.
Old October 4th, 2014, 11:04 PM
Breen
Breen Brunetti
1997 Defender 90
I'm not getting sparks now. Only got one when I wiggled connector plug into switch. Now I get absolutely nothing. So I think I blew a fuse, but have no idea where the fuse is.
Old October 8th, 2014, 11:52 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Post a picture of the switch, maybe we can ID it for you.
window
Source for Stainless Steel Window Studs and Window Quick Nut Fasteners (D90) Dragon Breath Defender Technical Discussions 19 May 8th, 2017 12:15 PM
Fuse Box: Glass fuse --> Spade Fuse gonzanc Defender Technical Discussions 20 October 27th, 2016 11:54 PM
60amp accessory fuse B blowing in main fuse box owen Defender Technical Discussions 5 March 31st, 2013 09:18 AM
F/S Brand New Powder Coated Window Latch Assemblys/ Window Locks Buddie For Sale - Parts 4 April 7th, 2012 07:04 PM
Passenger side sliding rear window for a 90 or 110 roofside and one fixed window evilfij For Sale - Parts 2 June 2nd, 2009 10:46 AM
