Electric rad fans in hot climate areas ? - Defender Source
Old February 25th, 2013, 10:36 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Hi,
Anyone running electric rad fans in hot areas, esp the Flex-a-lite 292 setup ?
Am at the point where I need to order a new rad & have to decide between a mechanical VC or electrics. Engine is a 3.9 at present (will be a 4.6 later) and running Megasquirt so fans will be controlled off the ECU if I go electric. Just not 100% confident that twin 12's or 13's will be enough in the middle of summer. Can get prity warm here in the BC mountains.
Comments please.....
Old February 25th, 2013, 10:40 AM
The Dro
Dro
1988 Ninety
I was running electric fans on my 4.6L Disco and it ran very cool.
The Hooptie has a FAL setup. Aluminum rad with dual electric fans and oil cooler ports.
Old February 25th, 2013, 10:41 AM
Pretty warm in BC Mountains? Don't think the 30Deg C you pretty much max out with is all that hot. Stick with the Viscous coupled fan. It works just fine in much hotter temps.
Old February 25th, 2013, 10:43 AM
Have you thought about a separate (read: big) oil cooler with dedicated fans?
Old February 25th, 2013, 10:49 AM
As long as the engine and cooling system is in good condition it shouldn't be an issue running the stock setup ... some of us run and RRC 11 blade fan which fits tighter in the NAS defender radiator shroud and possibly provides better cooling.
If you are really concerned and not running AC - I'd run a 11 blade setup with an auxillary push fan on the front of the radiator ... and see how many times you need to use it.
Don't buy a heavy duty fan clutch ... they just run the fan harder when you don't need it and suck gas as well as making lots more noise.
Old February 25th, 2013, 10:54 AM
Andy, just go by the wreckers and pick up the biggest fan that will fit. Have a look at the engine in the car that you are pulling it from. Does it have a lot more horsepower than your truck or not? don't waste money on a aftermarket fan. OEM fans from real cars are much better quality and much cheaper (used).
The key to using electric fans is choosing a large enough fan and doing the install, wiring and control to OEM levels. Once you do that, there will not be any problems.
Old February 25th, 2013, 11:05 AM
If you do alot of water crossong, electric is nice so you can switch it off. Beyond that id run a mechanical fan, and you can always add an electric on a thermal switch to automatically come on.
-Jeff
if you do a lot of water crossings ... get a diesel!
Old February 25th, 2013, 12:04 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I should clarify... don't have a rad or any fan's for it at present, be it VC or electrical. Will need to source whatever I use.... not much luck for getting one here from a wreckers, nearest one is a couple of hrs away
Will be fitting a remote engine & trans oil cooler, both with fans on stats.
Can someone throw up a pic of the NAS VC fan shroud, is it a 2 part item ?
Thanks !
------ Follow up post added February 25th, 2013 09:05 AM ------
Control would be off Megasquirt if I go that way, the ECU is already modded for fan control.
fan
Custom NAS D90 electric fan cowl and fans, bosch starter, misc 3.9 stuff jaherring For Sale - Parts 2 May 28th, 2012 02:57 PM
I'm making a custom fiberglass electric fan shroud for D90, anyone interesed? jaherring Defender Technical Discussions 1 November 22nd, 2005 01:06 PM
electric fans mattdh Defender Technical Discussions 49 April 26th, 2005 07:24 AM
Electric Fans Davis Misc. Chit-Chat 3 August 31st, 2004 02:54 PM
Electric Fans & Air Conditioning javelinadave Defender Technical Discussions 12 June 6th, 2004 08:44 AM
