Electric Fans & Air Conditioning - Defender Source
Old June 4th, 2004, 01:35 PM
Cool Electric Fans & Air Conditioning
I am thinking of changing out the original engine driven fan with a Flex-a-Lite 210. I have a factory alternator and A/C system. My question is for anybody out there who has the same setup or has tried the same setup. Does the alternator put out enough power or am I creating another problem for myself?
Old June 4th, 2004, 01:49 PM
The alts good and if you get a puller fan you will be all set to put it in place of the clutch fan.
Old June 4th, 2004, 01:59 PM
That is the plan Mike. I just want to make sure there is enough "juice" to power the A/C system, 19.5 amps on the new electric fans, jammin radio, headlight, etc. I am looking for somebody who has ALL of this installed.
Old June 4th, 2004, 02:53 PM
I can run the E-fans, the AC, the heat, the radio (all 400 watts) the Fog lamps, the headlamps, and the wipers with no problems. Last winter the Ac pushed out heat sometimes so I would put it on high at the same time as the heat on high with everything else. Is that ALL enough for you.
Old June 4th, 2004, 03:09 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Why go electric? Doesn't make much sense to me. It's one more electrical failure waiting to happen.
Old June 4th, 2004, 03:40 PM
You Diesel gys just don't get it.
Old June 4th, 2004, 03:41 PM
I think my viscous coupling is on its way out. It is not much more $$ to put in new electric fans. I am also hoping for a bit more MPG and a reduction in noise. All knowing Mike (AKA....AKM ), any thoughts on the MPG and noise situation?
Old June 4th, 2004, 04:06 PM
A bit noisier at idle no real change in mileage as the viscous only should really be engaging at low speeds (under 20-30 mph). I never realy keep track of milage as I fill up at about 170 miles and put in 14 gallons. And whats with the comment ???? Would you like replies with
Old June 4th, 2004, 04:15 PM
Only 170 miles? Wow, I go 220-ish miles and put in 14 gallons. As for the I am just yanking your chain.
Old June 4th, 2004, 04:27 PM
Well 170 is lasts a week and on average thats with 4+ hours of wheeling each week and very little highway. Don't look for any real mpg or power improvments but when I looked into it the clutch fan was more then the 210 flex.
Old June 5th, 2004, 12:39 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Because v-coupling sucks and doesnt do the job. Electric dual fan will pull more air than the stock unit could ever do, and if you take the extra step to wire them right, you can turn them on or off on demand when you need it to be running, not wait until your engine is already on the verge of overheating. Or not running as in deep water crossings.
Chris von C
[/size]
Old June 5th, 2004, 01:55 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Did Defender's come with a stock electric fan? When I bought mine I had both the clutch fan and a single electric in front of the radiator.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old June 6th, 2004, 08:44 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
The one in front is for the A/C.
Jimmy Buffett
electric fan, fan
Air Conditioning Parts Question for 1995 D-90 Retrofit Heath Defender Technical Discussions 2 May 25th, 2005 02:54 PM
electric fans mattdh Defender Technical Discussions 49 April 26th, 2005 07:24 AM
Air conditioning scottheise Defender Technical Discussions 4 October 8th, 2004 10:13 AM
Electric Fans Davis Misc. Chit-Chat 3 August 31st, 2004 02:54 PM
