Electric Fans, a worthy upgrade? - Defender Source
Old April 16th, 2006, 11:37 PM
rustydefender
Russell Newton
97 D-90 sw
I've been thinking about replacing my standard fan with an electric one or a pair of electric ones,but are the benefits worth the cost and labor?
Old April 16th, 2006, 11:39 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
For me, it's been a fantastic upgrade. Gives me more room to work on the truck, slightly better gas mileage, and cost less than replacing the old burnt up viscous coupling.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 17th, 2006, 06:33 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
I agree
I have to agree with the above and it makes for a much neater installation too
Old April 17th, 2006, 07:54 AM
GeoParth's Avatar
GeoParth
George Parthmer
1995/d-90 #2715 yellowST
it def. helped with my overheating issues. however, i havent had them in during a 100+ degree day sitting in traffic in august yet ... but, still a worthy investment. def. cheaper than a new radiator. i remember hearing someone say that they got a new radiator at napa for just a few hundred bucks, that might be the next step!
Old April 17th, 2006, 08:50 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Had them for maybe 8 months and had electrical failures after that point. They melted 2 fuses and a relay. So now I'm back to the stock set up with no complaints.
Jimmy Buffett
Old April 17th, 2006, 08:53 AM
Did you run a seperate fuse and relay for each fan or just one for the both of them?
Old April 17th, 2006, 08:56 AM
flippedrover
Tyler
'94 D-90
One for both. Good sized ones too.
Jimmy Buffett
Old April 17th, 2006, 09:10 AM
But you were runing those big goofy fans right?
And just for reference, I have been running my flexalites for over 2 years now without problem.
Old April 17th, 2006, 09:12 AM
flippedrover
Tyler
'94 D-90
Yeah the be cools. I still ahve them and all the wiring is still in the truck just needs power.
Jimmy Buffett
Old April 17th, 2006, 12:51 PM
Living in Phoenix my 90 would run very hot. I would have to turn off the A/C at long lights so not to overheat. I swapped out to Flexlite 210's and never had a problem again. There is a pretty good writeup on how to Click Here . I used the bulb in the top hose instead of the switch deal.
Old April 17th, 2006, 07:03 PM
btate
Bryan Tate
d90
Can you use both?
Put an electric on the front as a push fan? vs. wiring as a pull fan??
Old April 17th, 2006, 07:57 PM
for those of you that have made the "modification" did it have any effect on the AC and by what margin do you think your gas milage increased?
Old April 18th, 2006, 03:45 PM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
Silly question -- how would an electric fan improve your fuel economy?
The only thing I can think is that the standard fan adds a slight load to the engine. Perhaps I don't understand the physical forces involved but I can't imagine that the air flow would cause enough of a load to actually affect fuel econony.
Old April 18th, 2006, 03:59 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Less rotating mass. But not much.
Old April 18th, 2006, 05:26 PM
Hans's Avatar
Hans
Hans Haase
Less rotating mass, but the big reduction is in the air drag imparted on the engine. Not as bad when cold, but when the fan clamps down it does add up. I didn't get much milage difference, 1/4-1/2 mpg or so. But when you're only doing 12.5 on an average day, it does help.
-Hans
My oil line fix
Old April 18th, 2006, 05:59 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I put the 210's on the V8 and they have been great, they obviously suck more air under the hood than the viscious unit. Plus you can turn them off when wading.
Has anyone used flexilites on their 300tdi? I was thinking that the 2 of the 100 series would work but I'm looking for user experience.
Ne4x4 which are those in your photo?
Old April 18th, 2006, 06:33 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Do the 210's make more noise than the stock fan?
Old April 18th, 2006, 08:26 PM
A slight bit more noise but it is a different sound. This is a mod you do to keep your truck running cooler not a mod to gain M.P.G..................
For that you need to install the Tornado...........HaHaHaHaHaHa
Old April 18th, 2006, 10:54 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Hate to rain on this parade, but I've gone back to engine-driven clutch fan. When the clutch is fully engaged, the engine fan pulls way, way more air than my 210 set up did.
I have an analog coolant temp gauge tapped right into my rad below the top hose, and when that clutch engages the temp drops like a stone 10 to 15 degrees within 30 to 45 seconds of engagement. Huge amount of air. (New clutch -- my old one that I'd replaced with the 210s turned out to be blown.)
Anyone have actual statistics on how much air the fully-engaged engine fan pulls?
Doug W.
Old April 18th, 2006, 11:04 PM
Hans's Avatar
Hans
Hans Haase
No idea how much. But you are right though, engine driven fans do pull more air no matter what the electric companies say. Don't forget though, you're generating a bit more heat than the rest of us mere stock motor guys :-)
Every time this conversation comes up, I can't help but think about that oddball hydraulic motored fan on my Wife's old Lexus. Was driven off the power steering pump! Wierd.
-Hans
My oil line fix
electric fan, fan
Flex-a-lite 210 electric fans $150 JimC For Sale - Parts 3 September 21st, 2009 12:26 AM
I'm making a custom fiberglass electric fan shroud for D90, anyone interesed? jaherring Defender Technical Discussions 1 November 22nd, 2005 01:06 PM
electric fans mattdh Defender Technical Discussions 49 April 26th, 2005 07:24 AM
Electric Fans Davis Misc. Chit-Chat 3 August 31st, 2004 02:54 PM
Electric Fans & Air Conditioning javelinadave Defender Technical Discussions 12 June 6th, 2004 08:44 AM
