electric fans - Defender Source
Old May 22nd, 2004, 04:38 PM
mattdh's Avatar
mattdh
Matt Hurst
electric fans
thoughts , advice,and opinions on replacing thee viscous fan with electric fans anyone?by the way chris-very nice on the new setup!!!
Old May 22nd, 2004, 05:22 PM
Electric Cooling Fans:
Pro's
More HP from your engine.
Can turn off for water crossings.
Might be quieter than stock fan.
Con's
Needs electricity to run. (Bad alternator or bad battery = potential overheating, warped heads, long walk home thru the scary woods at night)
Engine driven fan is always available.
If it is hooked up now it is FREE!
Old Thread on this subject
Old May 23rd, 2004, 12:31 AM
I have electric Fans! They are noisy but they cool just as good as the clutch fan and it's easy to tell if they are woring right compaired to a clutch fan. They also make it allot easier to work on anything else under the hood as they free up space.
Old May 23rd, 2004, 10:00 AM
do you think they keep the motor cooler?
Old May 23rd, 2004, 11:44 AM
Hmmm, hard to tell. I never new when the clutch fan was going in and out but it feels like the electric fans pull more air. I have the Flexilite 210s I think.
Old May 23rd, 2004, 12:01 PM
cool was installation pretty straight foreward? this seems to be a good idea for the D-90 easy way to pick up a few HP and keep it cooler? I have only seen one of these and that was on a 2.5 diesal.
Old May 23rd, 2004, 12:04 PM
Hardest part is getting the old fan off. You need a big wrench or a strap wrench to hold the pully in place when you try to unbolt the BIG nut on the clutch fan. Putting on the new fan and wiring it is easy.
Old May 23rd, 2004, 12:17 PM
cool thanks for the insight. where did you purchase yours from?
Old May 23rd, 2004, 12:27 PM
From http://store.summitracing.com and here they are http://store.summitracing.com/partde...part=FLX%2D220.
Old May 25th, 2004, 11:50 AM
mattdh's Avatar
mattdh
Matt Hurst
mike you posted the link for the 220 and the guy in the write up under custom mods used the 210?which do i one do i buy?
Old October 9th, 2004, 09:54 PM
The 210 comes with controls, the 220 without. Not exactly sure if you need the controls. I do know you'd still need to buy a override switch if you wanted that (and you do) for the 210...
I am contemplating this mod too, but as always the price is just enough to make you go mmh.
Old October 9th, 2004, 10:12 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Other advantage is that the electrics blow air even when you are running at low rpm off road, rock climbing, etc. I have the 210 Flexalites with the controls -- I have them set to come on at 180 degrees. I have a mechanical aftermarket temp gauge plugged into the hot side of the radiator so I can see what's going on, and the engine has a 160 degree thermostat now. My AC fans come on at about 220 degrees without the AC running (with AC on, they run all the time). 220 is kinda warm and I'd like to figure out how to get those ac fans to kick in at about 200 instead. (Remember I have unusual cooling issues 'cause of the engine.) Doubt there is a way to change that, but open to ideas...
Old October 9th, 2004, 10:23 PM
Ok, but what I want to clear up is if I need the "controls". The plan is to buy the flexalite 210/220, the vw fan switch (Beck/Arnley 201-0809), and a switch to override it.
So would I need the controls? Aren't the switches all the control I need?
Sorry for the questions - I'm just a CB and can save I can save $25 if I get the 220. Thanks,
charles
Old October 9th, 2004, 10:53 PM
Charles, You don't need the controls, you can use 2 30 amp relays instead, thats what I use, they are cheaper and easier to replace. You just use the VW switch to turn on the relays. I have each fan run on it's own relay and fuse, so if one fan dies it does not take out the other. I can post a wireing diagram I have at work on Monday.
Doug why not replace the AC T-stat switch with the VW one that Charles is using? I am sure they sell different switches that turn on at different temps. I bet they have one that comes on at 195*.
Old October 10th, 2004, 09:48 AM
Thanks Mike. Please send the diagram.
I'm making one last attempt at trying to find a (cheap) US counterpart to the fan clutch, and If I can't pull that off, I'm getting a flexalite 220!
Doug, from the reading I have done, you don't need the switch for the AC, even if you use it. Just hard wire the AC fan to come on all the time when you are running the AC (ie bypass the switch) and use the switch location for the flex.
charles
Old October 10th, 2004, 02:37 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Something I found out at MAR is turn the AC to hot and the fan will come on with out turning on the compressor. Had hot running issues at MAR. Charles let me know if you need a hand with the install. As I'm headed that route soon too.
Jimmy Buffett
Old October 10th, 2004, 06:18 PM
Actually the best is to just unplug the lead to the compressor and run the ac. Works for me
Hey Tyler - just noticed your edit. I'll let you know if I go that route. Not to jynx myself, but it sounds like the hardest part is removing the old fan.
charles
Old October 11th, 2004, 04:22 AM
Vadim
vadim
95 D90
I just change my clutch fan to electrical fan.Me and my friend went to local junk yard and pick up fan from "Eagle" (car),then We pick up small relay and fuse box from some other old car.Of course we install switch from VW.Fanny thing...fan from Eagle fit perfectly.It's even bolt right in,I don't make any mod to radiator ) When I open hood now ,it's look like was factory bult,and always been here ) Actually my friend done such of good job )
Old October 11th, 2004, 06:56 AM
flippedrover
Tyler
'94 D-90
Charles. Cool. Its not too hard to get off. Had the water pump done before MAR.
Jimmy Buffett
Old October 11th, 2004, 10:42 AM
Hi Vadim
Now were talking! Although around here, we can't go into the junkyards - they only let you buy the stuff they pull.
So... Do you happen to know what year eagle? Roughly what did they charge you? Specs on the relay too if you have them
Also, regarding switches, I'l like to put a "stock looking" switch inside. I have something that looks like a dummy switch for a rear defroster or something that i could replace. Anyone know where I can get something like that?
charles
electric fan, fan
Flex-a-lite 210 electric fans $150 JimC For Sale - Parts 3 September 21st, 2009 12:26 AM
Electric Fans, a worthy upgrade? rustydefender Defender Technical Discussions 21 April 19th, 2006 07:15 AM
I'm making a custom fiberglass electric fan shroud for D90, anyone interesed? jaherring Defender Technical Discussions 1 November 22nd, 2005 01:06 PM
Electric Fans Davis Misc. Chit-Chat 3 August 31st, 2004 02:54 PM
Electric Fans & Air Conditioning javelinadave Defender Technical Discussions 12 June 6th, 2004 08:44 AM
