Electric Fan ..yeah yeah - Defender Source
Old February 16th, 2011, 12:42 PM
Rugbier's Avatar
Rugbier
Gustavo
I was thinking on installing an Electric fan set up , and questions came up in my head ( yeah go figure )
What difference would be installing a sucker style ( in front of radiator ) as opposed to a blower style ( behind the radiator )
reason, well in front of radiator there are no hoses to bother and bigger surface and probably mounting bracket fabrication will be easier.
I have a 22" x 17" empty area behind the radiator ( intercooler is mounted on the left ) and a 28"x17" if mounted in front.
What kind of ( here in US ) fans are vailable to accomplish this? shrouded or not ? etc.
Also what to do with thermostat ( and of course a bypass for manual when fording )
NO SIGNATURE
Old February 16th, 2011, 12:46 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I have a 200tdi and I ran a single flexlite over the rad with a switch in the thermostat housing. It took a while to find the right switch, but I finally got a VW that turns on at about 195.
Old February 16th, 2011, 01:16 PM
Sorry, what engine? On the 200TDI, a Taurus fan fits with very few mods using the stock shroud supports.
http://www.landroveraddict.com/smf/i...topic=369251.0
Most fans are design to pull from behind. You need a special fan designed to push in order to mount in front.
------ Follow up post added February 16th, 2011 11:17 AM ------
For control, you can't beat the DCControl products, http://www.dccontrol.com/
Old February 16th, 2011, 01:28 PM
The Dro
Dro
1988 Ninety
There's no mechanical difference between the pusher (mounts in the front) and puller (mounts in the back). Just where they mount and air flow... one pushes air through the rad... the other... well, you get the idea.
I have a very nice and well prices Flex-a-Lite... the FAL rep just told me I can convert mine to pusher.
Let me know.
Old February 16th, 2011, 01:38 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
A puller turns into a pusher by switching the wires. That said, a puller is always better in a front of vehicle application because it does not obstruct airflow. The difference is minor. Get in where you fit in.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 16th, 2011, 01:55 PM
I believe the fan blade orientation differs for push/pull as well, so will be less efficient if you just swap polarity.
Originally Posted by pendy
I'm here for the D's
Old February 16th, 2011, 02:15 PM
That is not true for all fan styles. Many are designed to only flow in one direction and reversing rotation makes them very inefficient.
It is important to do the design and install to an OEM level with such an important system as cooling. Too many people do hack electric fan installs and then blame the electric fan for the problems.
Old February 16th, 2011, 02:59 PM
the flex a lite black magic will fit very nicely on the 200/300 size radiator and has its own built in shroud. I use one on my 3.0 conversion in my 109 and despite perennial head gasket problems the engine has never actually overheated. Well, except for the time it ran a gallon low on coolant but that was not the fan's fault. The thing really blows. Or sucks...whatever...
http://www.flex-a-lite.com/auto/asse...ded-300wht.jpg
Old February 16th, 2011, 03:21 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Talk to Pendy about his clutchless fan. I installed it and it pushes a huge amount of air through the engine bay. Has a nice hum too. My engine runs noticeably cooler.
I am not sure it will work with your configuration but might be worth a try.
http://www.defendersource.com/forum/...eferrerid=4014
ID:	35847   Click image for larger version
Old February 16th, 2011, 03:24 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
True, but it works on most fans. And the ones it does not can usually be reversed inside the body.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 16th, 2011, 03:38 PM
Rugbier's Avatar
Rugbier
Gustavo
3 variance of Black Magic, 1 no var speed, does it come with brackets and switches?
NO SIGNATURE
Old February 16th, 2011, 03:57 PM
i got the universal one and yes it came with the thermostat, brackets, etc. I made my own wiring harness. Come to think of it this will not be ideal for the tdi as it will not pull through the intercooler, only the rad. They do make some wider fans but then you are into the $3-500 range. What is wrong with the stock fan/shroud setup again?
Old February 16th, 2011, 04:23 PM
The Dro
Dro
1988 Ninety
I strongly recommend the Flex-a-Lite 295... it's a great fan and comes with variable speed controller.
Old February 16th, 2011, 04:44 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
The kenlow fan on my 200tdi will drop water temp 20 degrees in 2 or 3 mins. It's wired to a switch on the console and have yet to see over 195 even with a load of junk in the back
Old February 16th, 2011, 05:48 PM
My Taurus fan does that in 10 SECONDS.......at minimum speed.....
Old February 17th, 2011, 04:06 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
your gauge is broken...simple physics, you can't cool anything that quick...
Old February 17th, 2011, 04:24 PM
Rugbier's Avatar
Rugbier
Gustavo
Frank send me a pic and model of your kenlowe please.
Also does it stay away from the intercooler? covers it? hoses on the way?
NO SIGNATURE
Old February 17th, 2011, 05:04 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
He's telling the truth. That Taurus fan is ludicrous. On high it will pull your car down the road.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 17th, 2011, 05:12 PM
Clarence, now that you've had it installed for a few months, how much louder is the set-up than stock?
Old February 17th, 2011, 06:43 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
ok goose...it doesn't cover the intercooler and I have no interference issues...I know the taurus fans rock, I ran them for a while on my D2, but 20 degrees in 10 seconds is a stretch.
electric fan, fan
Electric Cooling Fan 97 info needed. WHITE RHINO Defender Technical Discussions 8 January 8th, 2012 02:11 PM
I'm making a custom fiberglass electric fan shroud for D90, anyone interesed? jaherring Defender Technical Discussions 1 November 22nd, 2005 01:06 PM
Twin Electric fan kit for V8 D90 kiphartzell Wanted 2 March 17th, 2005 01:06 PM
Did 1995 SW D90s come with an electric fan? arbik Defender Technical Discussions 8 March 1st, 2005 01:27 AM
Electric Cooling Fan Brackets wea Wanted 0 December 8th, 2004 12:52 PM
