Electric Fan ..yeah yeah - Page 3 - Defender Source
Old April 22nd, 2011, 03:57 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Taurus fan FTW. Two speed, sturdy, cheap and available everywhere. Taking the engine driven fan off my RRC was the best thing I did to that engine. Ran cooler and quieter, no worry about the fan drowning the dizzy when wading.
Tony
1984 110 "Smokey" (sold)
Old April 22nd, 2011, 09:54 AM
Originally Posted by CDeWan View Post
Sorry to revisit this - What year Taurus' would you guys recommend? and is this the same for a 3.9v8?
It is my understanding that the Taurus fan does not fit on a V8 90. The motor on the fan hits the water pump. You need one of the dual fan options.
------ Follow up post added April 22nd, 2011 07:57 AM ------
Originally Posted by dsh12 View Post
And a little off subject, but the intercooler doesn't need airflow??
It is pretty rare for cars to have fans on intercoolers. You need intercooler air flow with sustained , high boost. This is pretty hard to get except when on the road, where you are moving fast.
Old April 22nd, 2011, 02:20 PM
CDeWan
Clay DeWan
5.3L beastie
Can anyone confirm John's reply that the Taurus fan won't work on the V8 defender?
Old April 22nd, 2011, 04:23 PM
Originally Posted by Red90 View Post
Sorry, what engine? On the 200TDI, a Taurus fan fits with very few mods using the stock shroud supports.
http://www.landroveraddict.com/smf/i...topic=369251.0
Most fans are design to pull from behind. You need a special fan designed to push in order to mount in front.
------ Follow up post added February 16th, 2011 11:17 AM ------
For control, you can't beat the DCControl products, http://www.dccontrol.com/
John, how weather resistant has that flexilite controller been for you? is it dunkable for wading? doesn't seem to say in the install manual or the website? Are you still happy with this controller?
Old April 22nd, 2011, 05:37 PM
I have not had any trouble with mine in 3? years. I drive through water over the bonnet a lot. It is mounted high (inside upper lip of wing) though.
I had and would suggest the DCControl unit. It is fully waterproof and better designed. I only bought the FAL unit because at the time DCControls was not selling to the public. One caveat...if you plan on an override and defeat switch for the DCControl, talk to me for details. The required wiring is NOT obvious...
------ Follow up post added April 22nd, 2011 03:43 PM ------
http://www.defendersource.com/forum/...ead.php?t=3209
Old April 22nd, 2011, 05:49 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
[QUOTE=Red90;277929]It is my understanding that the Taurus fan does not fit on a V8 90. The motor on the fan hits the water pump. You need one of the dual fan options.
I believe you need the 2.5" width option pulling 2500 cfm. On the topic of CFM, isn't the stock fan setup rated at 2700 CFM??
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old April 22nd, 2011, 09:45 PM
dsh12
Daniel Hayes
Correction: I believe that is 2 5/8".
Dan
Old April 25th, 2011, 09:03 PM
Thanks. Is it the 2sp unit that would be the one to get? I looked all over DCC's site and didn't see anything about waterproofness. I want to make sure I get one fully durable and waterproof, as I don't need an electric fan failure in travels through central america and elsewhere.
Also, I actually heard back from flex-a-lite technician for my inquiry abour wading, and he said it's "weatherproof not waterproof". I asked again specifically about short duration immersion for things like wading and he said and I quote
"I think if the control is immersed, it will no longer operate.
David Heutmaker
Flex-a-lite
253-922-2700 "
Does anyone know the amp draw of the Taurus fan setup?
Old April 25th, 2011, 11:48 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
A lot. I had to get an 80 amp fuse to handle it. The spike is startup though. I am not sure on the numbers for sure though. My buddy thinks a 50 amp spike.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 25th, 2011, 11:52 PM
geez! i only have an 85 amp alternator! maybe this isnt such a good idea.
Mark Kellgren
KM4BOR
Old April 26th, 2011, 12:12 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thats just startup spike on the 3500CFM (mack daddy) fan speed. Normal draw is not that bad. And you won't need the higher speed fan for more than a minute at a time, if that long.
I am putting 2 of these on my Diesel pusher motorhome. Don't be afraid.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 26th, 2011, 10:12 AM
I have not seen a two speed unit, but the variable speed ones are fully encased. Can't hurt to send him an email. His customer service skills suck, but he usually responds....
Either the two speed or the variable speed will work fine. The Taurus fan is around 30 amps.
There is a 3rd choice as well. http://www.spalusa.com/store/main.as...tem=FAN-PWM-V3 I have no experience with this one but it looks good although there is some internet chatter that it's current rating may not be good enough.
electric fan, fan
Electric Cooling Fan 97 info needed. WHITE RHINO Defender Technical Discussions 8 January 8th, 2012 02:11 PM
I'm making a custom fiberglass electric fan shroud for D90, anyone interesed? jaherring Defender Technical Discussions 1 November 22nd, 2005 01:06 PM
Twin Electric fan kit for V8 D90 kiphartzell Wanted 2 March 17th, 2005 01:06 PM
Did 1995 SW D90s come with an electric fan? arbik Defender Technical Discussions 8 March 1st, 2005 01:27 AM
Electric Cooling Fan Brackets wea Wanted 0 December 8th, 2004 12:52 PM
