Electric Fan Conversion - Defender Source
Old January 25th, 2015, 10:34 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I just replaced the thermostat (180 degrees) on my '86 D110, V8 and the temperature gauge will now barely move, where in the past it used to rest about 1/3 of the way from the left, when the truck has fully warmed up.
The truck runs fine, and doesn't seem to run "too cold", if there is such a thing. I'm in SoCal where the temperature never goes below 50 degrees in the winter but can sometime creep up into the low 100's in the summer.
Based on all of this, and because my fan and fan shroud need replacing, I am considering swapping out to an electric fan setup.
1) What's your opinion on this? Is this recommended on the defenders?
2) If yes, how many fans, 1 or 2?
3) What brand do you recommend?
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old January 25th, 2015, 10:40 PM
Search "Taurus" and everything you will ever need to know will come up.
Old January 26th, 2015, 06:39 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
So it looks like the Ford Taurus dual speed electric fan is the way to go, although the majority of the posts refer to the 200TDi and 300TDI. A couple of questions then:
1) Is the electric fan conversion recommended for a V8? Apparently, the Diesels do not produce as much heat as the gas engines, and require less cooling to begin with..
2) Will the Taurus fan fit behind the radiator in a V8? A few posts seem to think NOT.
Thank you - Samer
2003 Discovery II
Old January 26th, 2015, 06:51 AM
Interesting idea. Subscribed.
Old January 26th, 2015, 06:57 AM
New thermostat is faulty.
Old January 26th, 2015, 09:09 AM
sounds like it
Old January 26th, 2015, 09:25 AM
Faulty new thermostats are fairly common. There should be no heat in the radiator until the engine reaches normal operating temperature. If there is, the thermostat is leaking.
On the fan question, it is my understanding that the Taurus fan hits the water pump and you need to go with a dual fan setup for clearance reasons.
Old January 26th, 2015, 09:38 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
That's what I was thinking, or possibly coolant temp sensor failure? Or wrong temp sensor altogether?
Old January 26th, 2015, 10:30 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
The temperature sensor was not touched. The temperature gauge is registering, but much lower than before.
It didn't even occur to me that the new thermostat could be faulty, possibly stuck open, or maybe even not seated properly in the housing when I installed it, but how would that affect the engine temperature? Even if there were no thermostat installed at all, wouldn't the engine temperature reach it's normal operating range at some point? It would just take a lot longer obviously.
Thank you - Samer
2003 Discovery II
Old January 26th, 2015, 10:32 AM
No, the engine would not ever reach normal operating temperature unless pushed very hard. The thermostat is what control the engine temperature. IME, half of new thermostats are faulty.
Old January 26th, 2015, 11:02 AM
Essentially - an engine and radiator / fan setup is capable of cooling the engine under the harshest working conditions. Under less than harsh conditions the thermostat stays closed to allow heat to build up in the engine and reach operating temp.
A thermostat keeps the engine warm rather than keeping it cool.
It can fail in 2 ways ...
- Fail open - engine never gets to temp
- fail closed - engine overheats as coolant doesn't flow into the radiator.
Old January 26th, 2015, 11:34 AM
Samer,
Sorry I missed the V8 part. On my NAS 90 I used a dual fan model from Flex Fan. It wasn't cheap but it cooled very well.
Old January 26th, 2015, 12:08 PM
Flex fan dropped that unit. There are similar dual 12 inch units out there.
Old January 26th, 2015, 07:28 PM
carlosz's Avatar
carlosz
Carlos
I'm using an electric dual fan set up out of Chrysler minivan, almost exact fit on a v8 radiator on a classic.
the truck ran like a "raped ape"
A fussy warm weather creature...
Old January 26th, 2015, 08:48 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Carlos,
Can you please be more specific as to which year Chrysler minivan you got that dual fan setup from?
Thank you - Samer
2003 Discovery II
conversion, electric fan, fan
Electric Cooling Fan 97 info needed. WHITE RHINO Defender Technical Discussions 8 January 8th, 2012 02:11 PM
SPAL 11" Electric Fan and X-Eng X-Fan Kit crown14 For Sale - Parts 2 February 5th, 2010 01:12 PM
Twin Electric fan kit for V8 D90 kiphartzell Wanted 2 March 17th, 2005 01:06 PM
Did 1995 SW D90s come with an electric fan? arbik Defender Technical Discussions 8 March 1st, 2005 01:27 AM
Electric Cooling Fan Brackets wea Wanted 0 December 8th, 2004 12:52 PM
