Electric Cooling Fan 97 info needed. - Defender Source
Old August 10th, 2004, 12:24 PM
WHITE RHINO
JAMIE EKLUND
1997 D90 Yellow
Just was wondering if anybody had any info on what triggers the Electric fan on a 97 D90 to come on. Mine is seized up, I am going to replace it but I can't find any blown fuses? I just want to make sure after I replace it, It will come on again with the factory settings. Many thanks for any response.
Old August 10th, 2004, 01:09 PM
It should kick in when you turn on the AC.
Old August 10th, 2004, 04:09 PM
On a 97 the ECU runs the show. There is a trinary switch that runs that fan. Unlike a lot of other trucks, the fan is not suppose to run whenever the A/C is on (according to the dealership). It is suppose to run when the A/C system reaches some insane high pressure or when the ECU thinks that the engine is going to overheat (above 235 degrees). The engine officialy overheats at 240 degrees.
It does not turn on with the A/C as Mike stated on a 97
Old August 10th, 2004, 09:54 PM
Well then! You live you learn.
Old August 11th, 2004, 12:33 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Of course, a little temp switch added to the radiator could change all that
Old August 11th, 2004, 02:25 PM
You can also cut the wiring, add a relay and wire it up to come on when ever the A/C is on. I think that little fan retails for about $250. You would be better off getting some after market fan to use for supplemental cooling or go with the total electric set up that is listed in the custom mod section. That is what I am going to do this fall when the temperature in my garage dips into double digits! (Yesterday it was 124 degrees at 3:00 P.M. with the door shut. The record is 139 degrees! )
http://www.defendersource.com/mod/fan.html
Old December 15th, 2011, 07:27 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Curious, where do you guys buy your flexalite 210s nowadays? Couldn't find them on summit racing.com.
Robert Deniro
Old January 8th, 2012, 02:00 PM
JKC
1997 D-90
You can buy the original fan direct from the manufacturer - Spal
VA11-AP7/C-57S FAN (10") 79.4500
Under 90$ shipped to your door - just need to cut of the generic connector and put on the one from your dead fan. Or you could spend $200+ on the same fan with the right connector already installed!
Old January 8th, 2012, 02:11 PM
Google it, there seems to be several places that have them, including Four Wheel Parts.
97, fan
I'm making a custom fiberglass electric fan shroud for D90, anyone interesed? jaherring Defender Technical Discussions 1 November 22nd, 2005 01:06 PM
Did 1995 SW D90s come with an electric fan? arbik Defender Technical Discussions 8 March 1st, 2005 01:27 AM
Electric Cooling Fan Brackets wea Wanted 0 December 8th, 2004 12:52 PM
looking for a viscous cooling fan drork Wanted 1 July 1st, 2004 11:29 PM
