Electric Brake Control on 85 exMOD Defender 110 - Defender Source
Old August 17th, 2016, 01:08 PM
GRNWOLF's Avatar
GRNWOLF
1985 Defender ex MOD OM617
Hello and thank you in advance.
I'm looking to add brake control for trailering to my Defender. I've seen plenty of wiring harnesses for adding four way plugs but want the full shebang with the 7-way plugs and proportional braking.
Before I go reinventing the wheel, I thought it wise to ask here first.
I've looked at various sites and this one seems to have a comprehensive list of options: Hitch Wiring SHIPS FREE + Giant Selection
In the top right select 1990 Land Rover Defender and it'll narrow it down (no option for my 85 there).
I'm wondering what others have done as far as the Brake Controller, Wiring Harnesses, "Modulite" protector, etc.
I have seen the Prodigy RF and I'm not a fan right now plus I have too many trailers. Something about RF controlling my brakes I don't feel too secure about, so I'd prefer a wired system.
For Controller I was thinking the Prodigy IQ or P3. Everything else from there I'm stuck on. The Defender does have the military plug on it but I have no solutions for that.
GRNWOLF
1985 Defender 110 ex MOD Wolf Tithonus; OM617
Phoenix, AZ
Old August 17th, 2016, 02:16 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I guess the bigger question is...what do you plan to tow with that little 2.5??
Old August 17th, 2016, 07:39 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If you do not have the trailer connection in the chassis harness at the rear cross member then you can use the wiring in the Right rear to connect everything up. You will have to get a converter and run wiring for the brake controller. You should have a constant power, purple wire, back there. I would fuse that wire if you use it.
Land Rover 110
Old August 18th, 2016, 09:07 PM
GRNWOLF's Avatar
GRNWOLF
It has an OM617 in it now purrs like a big kitty.
Sent from my XT1060 using Tapatalk
------ Follow up post added August 18th, 2016 07:09 PM ------
So I was basically on track then? The converters and circuit protections I linked to would work then?
GRNWOLF
Phoenix, AZ
110, brake, defender, defender 110, mod
New, never installed cruise control kit! Yes, cruise control for your D! - For Sale HeloBubba For Sale - Parts 6 August 4th, 2013 09:52 PM
Brake options for my 109' IIA hybrid electric cgalpin Series Technical Discussions 13 July 30th, 2013 01:14 PM
Land Rover 110 2.5 NA DIesel EXMOD for sale nathansharkey For Sale - Vehicles 1 September 13th, 2009 05:20 PM
Advice on fitting a US-seven pin and electric brake controller onto a '83 110? turbodave Defender Technical Discussions 4 June 25th, 2009 01:48 PM
1966 ExMod 109 pickup cab + NAS 110 Rolling Chassis phoenix37 For Sale - Vehicles 15 August 24th, 2008 03:11 PM
