EGT/ Pyrometer sender best location ???? - Defender Source
Old August 8th, 2008, 11:56 AM
I have been trying to figure out where these are best located. It seems there are two schools of thought- one 5-6 inches from the exhaust port (ie after the turbo) or before the turbo in the exhaust manifold itself. VDO sells a weld on bung so I'm guessing after the turbo on the downpipe ? This will be for a 200tdi Defender engine where the exhaust manifold is above the intake so easily accessable.
Old August 8th, 2008, 01:33 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Before the turbo is preferred since you will get a more accurate indication of the max temp in the head. After the turbo is generally used if it's difficult to install the EGT sensor in the exhaust manifold. I haven't tested it myself, but have heard that the after turbo location will be about 200 deg lower than before the turbo. So keep that in mind for max EGT's if you locate it downstream. I'm not sure about the 200 Tdi, but I thought the 300 Tdi's have a blank cover plate on the exhaust manifold where you can add a bung and install the EGT probe.
Old August 8th, 2008, 07:49 PM
Does the sender in any way impede the exhaust if put infront of the turbo ? 200 degree swing seems huge
Old August 8th, 2008, 09:01 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
EGT probes are relatively small in diameter, and won't cause a problem ahead of the turbo. I would extend it about halfway into the flowpath. A problem you could create by putting it ahead of the turbo is dropping chips into the turbo if you have to drill/tap a hole in the exhaust manifold. Best to remove it to do that work.
Regarding temp drop across the turbo, it's actually a good thing. Part of the turbo's job is convert heat energy (along with flow energy) into work to turn the compressor wheel. So the temperature drop is actually indicative of this.
Old August 8th, 2008, 10:15 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Sender unit ...
I had a sleeve welded on the exhaust manifold between the number 3 and 4 cylinder.
I will post pics in a bit.
Pat
Here goes !
Pat
ID:	14693   Click image for larger version
Kirk Lazarus, Tropic Thunder
Old August 8th, 2008, 10:18 PM
Mine is on the EGR blanking plate on the 300tdi - I guess that would be "downstream." That makes sense since I have never have never gotten above 900 in the Siskyous pulling a trailer.
Old August 9th, 2008, 11:31 AM
Pat,
Perfect ! Many thanks.
VDO Vision EGT pyrometer sensor installation. sundogcwolfe Defender Technical Discussions 10 September 25th, 2011 02:31 PM
200tdi EGT probe location ... Retrofit Defender Technical Discussions 3 May 15th, 2007 12:16 AM
Temp Sender Location DJ Menasco Defender Technical Discussions 10 August 28th, 2006 01:24 AM
Location for ARB Compressor Seriesman Defender Technical Discussions 10 August 15th, 2004 04:09 PM
Thread size for temp sender mgrgpg Defender Technical Discussions 3 July 1st, 2004 12:00 PM
