EGT pyrometer questions - Page 3 - Defender Source
Old September 13th, 2014, 12:34 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Jackie,
How did you make out with the longer probe? I noticed the same thing with the kit I got. Didn't appear the probe would be getting into the exhaust stream.
Pete
Old September 13th, 2014, 12:46 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
I never got the longer probe.
I forget the exact length of the probe that came with the VDO Vision gauge kit (look back through this thread I think I mention it), but after talking to lots of diesel guys both in and outside Defender Source, including marine diesel specialists, the universal conclusion is that the tip of the probe does not necessarily have to be in the center of the exhaust flow to obtain an accurate reading. It's more important to get the probe close to the head as possible (i.e. pre-turbo). The EGT blank plate on a 300TDI mani is perfect.
I think if you wanted an instantaneous reading, then yes, being in the center is important, but there is probably a 5-10 second delay anyway (with the VDO probe). There are probes that are thinner and provide instant feedback, but that's just not necessary in this application.
I've logged plenty of miles and heavy WOT runs in my truck since the EGT probe install and injector pump tune and the readings have been very consistent. I have not verified with an IR temp gauge, but I'm pretty satisfied that the VDO gauge probe I've used is providing accurate readings even though the tip is not in the center of the exhaust flow.
I will say that when you weld the bung adapter onto the blanking plate, make sure it's at that angle (not perpendicular to the face of the plate) and that you drill the hole in the blanking plat wide enough so that the bung can be sunk into the plate as far as possible to give you the most penetration into the manifold.
You will be fine. Good luck
EDIT: just quickly went back through the thread and I should add that Uncle Douglas was correct and that the fact I was only seeing temps in the 450-500 range was because my IP was lean and I hadn't put some adjustments on the IP. Ever since a trial and error period and many adjustments, we are running around 650 around town and 750-950 on highway WOT, full load for extended period will see 1,050 before the fact that you're simply going too fast for a Defender makes you slow down.
Old September 13th, 2014, 01:13 PM
Broncoduecer
peter
D90
Thanks for the info Jackie! Good to see the setup works. You're right that lean number got me wondering, but now it makes sense. I'll give this one a go and see how it looks.
Pete
VDO Vision EGT pyrometer sensor installation. sundogcwolfe Defender Technical Discussions 10 September 25th, 2011 02:31 PM
EGT/ Pyrometer sender best location ???? Uncle Douglas Defender Technical Discussions 6 August 9th, 2008 11:31 AM
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
Help - 1994 D90 Purchase Questions - NC uzj100 Defender Technical Discussions 6 November 1st, 2005 01:31 PM
Dumb questions to ask when looking at a defender... Grouchie@irdumb.co Defender Technical Discussions 2 July 6th, 2005 11:31 AM
» Defender Registry
Boomer
bsjbrown
Oliver
IvanKV
Add your Defender
