EGT Location - Defender Source
Old October 17th, 2010, 08:13 PM
EGT Location
So I had my diesel shop install the EGT probe while my turbo was being replaced. Pic below shows the location they picked, which is just off the exhaust manifold on the #1 pipe pre turbo. Ideally I wanted it on the collection point of the exhaust manifold, but I absolutely wanted to have it pre-turbo, not post; I don't want to have to do any fuzzy math when it starts peaking on hot summer days.
Downside of this location is I am only getting a read on the #1 cylinder, but the good idea is the reading should be the hottest the gases are coming out of the piston, so I'll back off earlier rather than later to prevent turbo damage.
Thoughts on this location? So far, running around town I'm getting around 450 in normal traffic, and once engine is warmed up, I can peak at 650 above 2k rpm.
Old October 17th, 2010, 09:21 PM
FrankenRover
Jackson
Series 3ish Mix&Mtch 2 get her go'n
Would recommend moving to the collection point. You won't get a clear reading if one of the other cylinders starts to lean out.
Old October 17th, 2010, 09:26 PM
Originally Posted by FrankenRover View Post
...one of the other cylinders starts to lean out.
EGTs go high with excess fuel. Lean is the normal condition and is cold.
650F ??? or 650C ??
Old October 18th, 2010, 09:28 AM
Originally Posted by red90 View Post
egts go high with excess fuel. Lean is the normal condition and is cold.
650f ??? Or 650c ??
650f.
Old October 20th, 2010, 03:05 PM
Roverowner's Avatar
Roverowner
Brian Love
95/Disco
100% agree on pre-turbo. IMHO, EGTs are for protecting the turbo (unless you are talking about a jet engine; but that is one big turbo). I can see the arguement on single cylinder vs further down, but I would think some other symptoms would present if you were having a (in your case) #2 or #3 cylinder issue. But as I think you have already proven something is better than nothing. did you get root cause yet?
Inspirational Thought of the Day
Some people are like Slinkies ...
Not really good for anything, but they still bring a smile to your face when
you push them down a flight of stairs.
1995 Discovery
Old October 20th, 2010, 08:02 PM
Originally Posted by Overlander View Post
650f.
That is nothing. On full throttle it should be going over 900 right away.
Old October 20th, 2010, 08:25 PM
This is a diesel. Fuel makes temp go up. Lean condition = cool. Mark sounds like you drive like a 70 yr old or you are WAY lean. You should be able to reach 1200 min on long interstate hills in 5th gear with your foot in it trying to maintain speed. Like John said above these gauges move quickly both up and down.
Old October 20th, 2010, 08:32 PM
I was guessing I was lean. It's the same setting as it was off the crate when Pendy received it for install. I always thought the engine may have more to give then it does, but never wanted to mess with the IP until I got the gauge in.
Sounds like I'm ready to richen it up and see what more this 2.8 has to offer on the upper end. Wow, that's going to be interesting.
Doug, am I good with just getting a read on #1 you think?
EGT/ Pyrometer sender best location ???? Uncle Douglas Defender Technical Discussions 6 August 9th, 2008 11:31 AM
200tdi EGT probe location ... Retrofit Defender Technical Discussions 3 May 15th, 2007 12:16 AM
Vibration location! Advice please.. EdF Defender Technical Discussions 11 January 1st, 2006 05:29 PM
Location for ARB Compressor Seriesman Defender Technical Discussions 10 August 15th, 2004 04:09 PM
XM Radio antenna install Location - Where? COSteve Defender Technical Discussions 37 July 11th, 2004 07:50 PM
