EGT kit? - Defender Source
Old November 5th, 2015, 08:44 PM
Matt_110's Avatar
Matt_110
Matt
110
EGT kit?
Is there a one-stop shop for getting the EGT gauge and sender? I've tried the search option and I know egauges.com was referenced, but I can't find anything LR specific. I'm trying to find something around 2"...if I have to modify the Raptor Dash instrument panel to fit the gauge that's fine. This would be fitted to a 2.8tgv (guessing the same fitment as a 300tdi). Oh, and digital gauge of course. An alarm would be neato. Thanks for any help gents!
Old November 5th, 2015, 08:59 PM
I use the one by Auber Instruments. They sell the probe too.
Old November 5th, 2015, 09:15 PM
I've often thought the same question as well. Do they sell one that has the probe setup for the EGR blanking plate?
Old November 5th, 2015, 09:19 PM
Matt_110's Avatar
Matt_110
Matt
110
Ah, I forgot about the blanking EGR blanking plate! Where does one find that?
------ Follow up post added November 5th, 2015 10:20 PM ------
It looks like their site is down, but I'll check back. Thank you
1987 110, 2.8TGV, ZF Auto
Old November 5th, 2015, 09:40 PM
RBBailey
RBBailey
1965 IIa
This is what Uncle Douglas posted for me: 310-153: Vision Black Pyrometers / EGT Gauge | VDO Gauges | eBuggies.com
Project:
1965 IIa SWB
Old November 5th, 2015, 09:47 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
There is this one from VDO. It has a probe that you can install in the blanking plate by welding on a fitting
http://www.egauges.com/ProductDetail...ctCode=310-953
------ Follow up post added November 5th, 2015 07:51 PM ------
Originally Posted by RBBailey View Post
Hmm that's funny. The only difference I see in that one is the part number and it's $9 less.
Old November 5th, 2015, 09:59 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
It's the removable plate on the manifold
Old November 5th, 2015, 10:03 PM
Matt_110's Avatar
Matt_110
Matt
110
Are you happy with that VDO? I will be doing some towing so I was hoping to find something with warning alarm or light
------ Follow up post added November 5th, 2015 11:05 PM ------
Thanks. I wasn't sure if mine had the actual EGR system. Hood latch is being a prick tonight
Old November 5th, 2015, 10:35 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I went with Westach, they build airplane instruments & they are reasonably priced. Three parts gauge , 2-1/2" probe, weld in bung.
Old November 6th, 2015, 07:52 AM
BullTrout14's Avatar
BullTrout14
1985/Defender 110
Another option is the McNally Electronics 2 in one boost/EGT guage they sell all of the above stuff including a blank off plate with the fitting already installed for the probe.
Boost/EGT gauge Combo Kit - McNally Electronics Store
And the guage fits right in place of the clock on a stock dash. I can grab a pic for you later today if you like.
Old November 6th, 2015, 09:31 AM
Matt_110's Avatar
Matt_110
Matt
110
Originally Posted by BullTrout14 View Post
Another option is the McNally Electronics 2 in one boost/EGT guage they sell all of the above stuff including a blank off plate with the fitting already installed for the probe. Boost/EGT gauge Combo Kit - McNally Electronics Store And the guage fits right in place of the clock on a stock dash. I can grab a pic for you later today if you like.
That looks perfect. I only saw the blank off plate for a VW though.
Old November 6th, 2015, 10:25 AM
BullTrout14
1985/Defender 110
This plate fits the 300tdi as well:
Qty | Item # | Description | Date Shipped | Tracking #
1 | MI1007-1 | EGR Blockoff Plate for VW ALH engine | |
Old November 6th, 2015, 11:01 AM
BullTrout14
1985/Defender 110
Here are a few pics of my guage, the EGT blank off plate and probe and the boost sending unit.
ID:	134065   Click image for larger version
Old November 6th, 2015, 11:09 AM
Matt_110's Avatar
Matt_110
Matt
110
That's it then. Much appreciated Brian!
Old November 6th, 2015, 11:21 AM
BullTrout14
1985/Defender 110
No problem, you will also need one of these to replace the plug on the back of the inlet manifold and insert the boost guage sending unit:
http://www.amazon.com/gp/product/B00..._detailpages00
I believe you only need the M12/1.5 fitting so if you can find one of those without having to buy the kit that may be a cheaper option.
kit
300 Td1 egt rises faster than the tach cdb Defender Technical Discussions 13 March 19th, 2009 09:05 PM
EGT/ Pyrometer sender best location ???? Uncle Douglas Defender Technical Discussions 6 August 9th, 2008 11:31 AM
200tdi EGT probe location ... Retrofit Defender Technical Discussions 3 May 15th, 2007 12:16 AM
EGT install... roverboy Defender Technical Discussions 11 April 1st, 2007 07:22 PM
