EGT Installed...temp range? - Defender Source
Old March 18th, 2016, 05:06 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
I installed my EGT prob just under the turbo inlet...on the highway today 3,800 RPM, 13.5 lbs boost and temp was at 950F...truck was running very well....around town at 3,00 RPM and about 8 lbs not really under load and running 650F....with a 19J I don't want to stress it to much...could prob crank the turbo manual boost up a tad more...but I think the at 950 F I prob shouldn't play with the fuel anymore...thoughts...?
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old March 18th, 2016, 05:21 PM
3800 rpm ?
Old March 18th, 2016, 05:43 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
On the 4K RPM gauge, the engine kind of tops out at 4K...I never adjusted the gauge so it may be off...not sure what these little 4cyl RPM range is...
Old March 18th, 2016, 05:53 PM
1300 F sustained should be your limit.
3800 rpm would be hitting the rev limiter.
Old March 18th, 2016, 06:50 PM
13.5psi on a 19J is a bad idea.
Old March 18th, 2016, 07:49 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
The RPM gauge may be off a bit...I does not hit the limiter until the gauge bottoms out at 4K...(I don't push it that far)...where is the boost recommended on that motor...?...BTW this motor is original at 83K miles...but do not want to kill it...it also has a big ass All Sport full size intercooler on it...
Old March 18th, 2016, 09:01 PM
The maximum in the manual is 9.3 psi.
Intercooler?
Old March 18th, 2016, 09:26 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Yes..when I imported it, a large intercooler had been installed sometime in the past...
ID:	145401   Click image for larger version
Madman EMS2 EGT/Boost/Temp Gauge BlackField Wanted 22 November 28th, 2015 01:10 PM
EGT/ Pyrometer sender best location ???? Uncle Douglas Defender Technical Discussions 6 August 9th, 2008 11:31 AM
200tdi EGT probe location ... Retrofit Defender Technical Discussions 3 May 15th, 2007 12:16 AM
EGT install... roverboy Defender Technical Discussions 11 April 1st, 2007 07:22 PM
