EGT fitting - Defender Source
Old October 21st, 2013, 12:36 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
EGT fitting
Getting to the point of fitting a VDO egt gauge, as I had a 200tdi and no egv blanking plate I have been searching for a fitting solution.
Found this clamp on the diyautotune.com web site.
Anybody used this or know of it? I want to get the probe upstream of the turbo for realistic readings, its either this clamp or drill and tap into the turbo casing. What have you done?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old October 21st, 2013, 12:48 PM
Just drill a hole in the mani and tap it NPT. You need to borrow a tap?
Old October 21st, 2013, 12:49 PM
Viggen's Avatar
Viggen
Jarrod
none
Theres your answer. Dont use that clamp. Do it right the first time. Taps are easy to find. I tapped into the exhaust manifold on my 3B.
Old October 21st, 2013, 01:18 PM
roverman2010
1985 LR 90 200Tdi
I have taps but there is just no meat on the manifold for tapping its all tubing with no flat spots. something turn up. Thanks guys
Any ways that clamp will not work, its for a 3/16" tip and the VDO tip is 1/4" what type is the vdo sensor J or K
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old October 21st, 2013, 07:33 PM
the vdo sender will come with a weld on bung. just pull the exhaust manifold, take it to a weld shop, have them drill and weld it on where you want it, and reinstall. all for the cost of a single gasket.
I wouldn't trust that hose clamp for any reason. it belongs in the Pep Boys isle with the license plate frame with skulls and the fuzzy dice.
Mark Kellgren
KM4BOR
VDO Vision EGT pyrometer sensor installation. sundogcwolfe Defender Technical Discussions 10 September 25th, 2011 02:31 PM
question about rear ladder fitting my ride chirider Defender Technical Discussions 1 December 7th, 2004 11:20 AM
Fitting Tickford top to 1997 ronward Defender Technical Discussions 13 July 16th, 2004 07:17 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
