EGR Sensor Port on 300Tdi Manifold - Defender Source
Old September 18th, 2017, 02:11 PM
Bayonet16's Avatar
Bayonet16
1984/110
I have a threaded port on the manifold. It used to have a broken sensor in it that was removed by guy who rebuilt the engine. Don't think I need the sensor, so does someone know the diameter and thread count for it? Would like to find a plug for it.
Thx
Old September 18th, 2017, 03:29 PM
Naplm00
Matthew
Probably 1/8-27 npt
Old September 18th, 2017, 03:34 PM
are you talking about the port on the intake manifold?
M12x1.5
http://www.defendersource.com/forum/...old-54314.html
Old September 18th, 2017, 03:40 PM
The factory plug is ETC5577. Same plug used for the the head temperature port and the block coolant drain. Quite cheap.
Old September 18th, 2017, 05:12 PM
Naplm00
Matthew
Sorry i read that as egt sensor port
Old September 21st, 2017, 12:03 AM
Bayonet16's Avatar
Bayonet16
1984/110
No, not the intake manifold. I guess it's really in the valley between the head and the intake manifold.
Old September 21st, 2017, 01:53 AM
Naplm00
Matthew
A pic may help
Old September 21st, 2017, 09:33 AM
Do you mean the EGR port on the maifold ? The egr was used only on later 300 models and the early models had a simple block off plate and gasket held on by two bolts. If yours had a sensor on it it was most likely a pyrometer as this is where they are typically mounted. The block off plate kit is cheap but my advise would be to fit another pyrometer. Its the most important gauge for a tdi.
Jason has the block off plates on ebay
http://www.ebay.com/itm/like/1122567...=ps&dispItem=1
300tdi egr Santini1228 Defender Technical Discussions 2 July 25th, 2017 03:50 PM
300Tdi turbo + manifold Talleyrand For Sale - Parts 12 June 19th, 2015 04:46 PM
FS: good take-off 300Tdi turbo, manifold, and downpipe jrose609 For Sale - Parts 8 May 23rd, 2012 11:15 PM
300Tdi exhaust manifold problems crown14 Defender Technical Discussions 12 July 8th, 2009 11:38 AM
