EFI to Carb - Fuel Pump - Defender Source
Old May 3rd, 2016, 09:49 PM
bluewave
95
Okay, Considering EFI to carb for the 3.9 I have. Before any body goes nutzo. i know. but im chasing tons of electrical gremlins.
One question i keep bumping into: The fuel Pump
I looked at past posts. Lot of mention that they left fuel pump in by used a regulator with return to keep PSI below 7/5.5 . Problem i see with this is one day the regulator goes out, then it floods the carb bowl.
So, anyone have ideas what to do with the fuel pump. It has two sets of wires. Was thinking about messing with those and just using the float readout, but thats all theory right now. Gut it to what level? throw it out? use it?
Any help much appreciated
Old May 3rd, 2016, 10:11 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I just happen to have one that I was going to post, Airtex E2485, was going into my new to me V8 rover but some where along the way a PO had chopped up the pick up and fitted an external pump.
PM if interested $35 shipped
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 3rd, 2016, 11:36 PM
bluewave
95
Thanks, but I have a holley fuel pump...
Trying to understand what to do with the existing fuel pump in the take.
Old May 4th, 2016, 07:21 AM
LRover's Avatar
LRover
J. Michael McCaig
Since you already have a replacement pump, I would pull the pump/sending unit out of the tank, remove the high pressure pump from the assembly, replace it with a short piece of fuel line, and reinstall the sending unit assembly. I have done this when I used a later model fuel tank in an earlier vehicle.
Old May 4th, 2016, 07:29 AM
I am pretty sure you don't have to do anything at the tank end. The fuel pump is a gerotor type, so it isn't blocking the fuel line or anything.
Old May 7th, 2016, 12:23 PM
bluewave
95
JMM, thanks. I was considering pulling the two wires to the pump and leaving the two wires to the float. i havent checked the diagram but was thinking would allow to read float and alleviate any wiring dangling. I am re-wiring this anyhow. You think this setup good or bad?
Old May 7th, 2016, 12:39 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I did as JMM described when I converted my LWB to diesel.
So no pump in there any more, just a signal from the float.
Rent my
fuel
Series Weber carb, distributor, fuel pump transientmechanic For Sale - Parts 2 May 7th, 2013 01:14 PM
EFI to carb conversion procedure wantone Defender Technical Discussions 5 May 3rd, 2013 12:39 PM
EFI Fuel Filter - Purolator F33144 hillstrubl For Sale - Parts 0 September 19th, 2010 02:44 PM
FS D90 EFI fuel pump ECR For Sale - Parts 0 June 27th, 2008 02:46 PM
EFI fuel pump options headdamage Defender Technical Discussions 0 August 11th, 2005 03:21 AM
