EFI harness plug - Defender Source
Old December 5th, 2009, 03:00 PM
EFI harness plug
I was cleaning out from under the seat and replacing the ECU, on my Classic there was a blue plug with nothing attached to it. I am not sure what it is for was wondering if anyone here could identify it. Also is photo two the tune resistor? In photo three some plastic plug wrapped in electrical tape to the EFi harness? What does the test book plug into?
ID:	23411   Click image for larger version
Old December 5th, 2009, 05:44 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
the blue plug in picture one is where the tune resistor would be if your rig had one. US spec RRC did not. The photo two is the voltage resistor for the coil signal to the ECU (6.8 V I think).
Matt Browne
Old December 5th, 2009, 06:08 PM
Interesting, I always thought that the tune resistor was spliced into the EFI harness. Ive not found all these plugs in my D-90's wiring.
Old December 6th, 2009, 07:34 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
There is no external tune resistor in these trucks. It is the basic tuning and to change it for other markets such as Saudi or Euro non cat (the 2 that I use for performance conversions) you add in a tune select resistor.
The Voltage resistor on the 90 is in the harness up by the MAF between it and the coil.
Matt Browne
Old December 6th, 2009, 08:04 AM
is the tune resistor available at Rovers North.
Help! need STC934 glow plug harness cabell Wanted 29 May 6th, 2015 08:05 AM
need Discovery II side repeater Harness Plug FlaD90 Defender Technical Discussions 2 September 16th, 2009 01:12 PM
Trailer harness plug and/or connector type spoolin440 Defender Technical Discussions 14 October 8th, 2006 04:37 AM
what does this plug in to? mattdh Defender Technical Discussions 6 November 2nd, 2004 11:59 PM
What does this plug go to??? Chris Cox Defender Technical Discussions 1 July 11th, 2004 03:24 PM
