Educate me on Tires for my 90 - Defender Source
Old August 10th, 2006, 11:39 AM
coryhula
Cory Hula
1995 D90
Ok, somebody educate me on what the difference between tires that are rated by size vs. ratios (if that's even the right question). What's the difference between 33, 35, 31, vs. a 265/75/16 and why would I choose one over the other? Also, do these differences impact turning capabilities, would offsetting or lifting be necessary to accomodate a tire measured in inches vs. millimeters?
Old August 10th, 2006, 12:01 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Probably discussed on this site/forum already. I did a quick google search with those keywords: "+tire +size +faq +turning +radius +radial"
The first hit I got looks decent (did not read the details): http://www.skoolie.net/forum/viewtop...9f52da0c8f312b
265 / 75 / 16:
- 265: width (in millimeter) of the tire
- 75: 75% of the width for the height (i.e. 265x75/100 = 198.75 millimeter)
- 16: size of the rim (in inches.... yeah I know....)
(theorical) Size of that tire: 16" + 2 x (198.75 millimeters) = 16" + (2 x 7.82") ~ 31.64"
MonLand
1995 D90 NAS
1996 Discovery NAS
Old August 10th, 2006, 12:04 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Loic, you beat me to the punch.....
33, 35, 31 etc. are the height of the tire in inches. 31x10.5 R15 says the tire is 31 inches tall, 10.5 inches wide with a 15 inch wheel. 265/75R16 is just the metric way of expressing tire size. There is no difference in the actual tire composition, tread, etc....265 means the tire is 265 mm wide and the 75 is called the aspect ratio and is a percentage of the first number (265 here). 75% of 265mm is about 199mm and that is how much tire is between the wheel and the top or bottom of the tire. Again, the last number means the wheel is 16 inches in diameter. If you want to find out how tall a metric tire is you must multiply the aspect ratio by the width (.75 x 265 = 199mm), multiply the answer by 2 to get the tire above and below the wheel (2 x 199 = ~398mm), convert to inches b/c i dont know the metric system (25.4 mm/inch x 1/398 1/inch = 15.6 inches), and finally add that answer to the wheel size (15.6 + 16 = 31.6 inches). Thus a 265/75R16 tire is 31.6 inches tall. Just be careful because every tire manufacturer is different and just because the tire says it's a 32 doesn't mean that it is exactly 32 inches.
Different width tires do influence turning ability as a wider tire will force a wider turning radius becuase the steering stops may need to be adjusted. Offset and lift are needed for certain size tires, but has nothing to do with metric versus standard measurements. If you want to know what tire size fits what lift I'm sure you there are several threads on the board which talk about it.
Hope this clarifies more than confuses...
Old August 10th, 2006, 05:08 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Also, check out the TIRES/WHEELS link on the top.. all the math is done for you. If you're an Excell geek, try the following:
Column A: 265
Column B: 75
Column C: 16
Column D (width in inches) : =A1/25.4
Column E (height in inches): =(A1*B1/100*2/25.4)+C1
Copy the rest of the cells down and you've just created your own tire calculator.
Remember what Mike said though, this is only the nominal height/width. Kinda like a 2x4 ain't really a 2x4. The manufacuturer can most likely provide you with the actual measurements and when all else fails, go to the tire store with tape in hand. I carry one in the cubby. My wife is embarrased to walk with me when I grab it because she knows that I'm gonna measure somebody's tires in the Wal-Mart parking lot.
Also, check out this thread: http://www.defendersource.com/forum/...light=255%2F85
It discusses a BFG M/T 255/85R16. You don't need a lift and requires no adjusting of your steering stops.
Old August 10th, 2006, 09:24 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I had to adjust the steering stops on my truck when going from a 235/85R16 to the BFG M/T 255/85/R16. I also didn't think it drove as well on the 255's. I went back to the 235/85R16 size ( new Cooper STT's) with my latest set of tires - 32" diameter and I think it drives and looks better. Ive also been able to crank the stops in and get back some of teh turning circle I lost with the 255's. NAS trucks come with the stops adjusted farther out than Euro models.
Old August 15th, 2006, 11:08 PM
Is there a reason you guys are not switching to 15" rims? It looks like the number of tires available in 16" is rather limited.
thanks
charles
Old August 16th, 2006, 12:05 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Bling baby, bling
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
90, tire, tires
Tires: an odessy souza Misc. Chit-Chat 37 December 14th, 2009 05:57 AM
Defender 90 Tires And Wheels bmj For Sale - Parts 0 March 23rd, 2009 02:16 PM
Tires, Tires, Tires Joe P Misc. Chit-Chat 28 August 9th, 2005 09:58 PM
4 BF Goodrich Mud Tires Jeremy Keith For Sale - Parts 5 March 3rd, 2005 07:09 PM
BFG AT Ko tires for sale Seriesman For Sale - Parts 6 August 18th, 2004 11:09 PM
