Edelbrock 500 manual vs automatic choke - Defender Source
Old August 20th, 2013, 08:10 PM
egor
kody martin
1986 Land Rover 90
Have a 3.5 v8.
Going to replace my SU carb set up with the Edelbrock 500 carb and 2198 manifold.
Anyone use this type with the automatic choke? Or, is it best to stick with the manual choke.
How difficult is it to set up the automatic choke vs manual?
Old August 20th, 2013, 08:26 PM
Last edelbrock I bought was a Performer for my boat. It has an automatic choke. It comes from the factory pretty much already set up. You need only supply 12V switched power to the choke and that's that.
Manual choke you obviously can choke it as much as you want, but the risk of flooding is way higher.
Old August 20th, 2013, 10:59 PM
Treys truck has a manual choke and we have not even hooked it up. Just pump the pedal 4 times when its cold and it fires every time.
Old August 20th, 2013, 11:43 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
I have the edelbrock Performer series 1404 carb with manual choke. I use the choke (I am not as cool as Uncle Doug). The real point is that it is very simple and it works. I do sort of wish I tried the electric choke for comparison.....
Firemanshort
1980 Stage One 109
Sterling, VA
Old August 21st, 2013, 07:54 AM
LRover's Avatar
LRover
J. Michael McCaig
In my experience I have found that the electric choke works well. I'm using the manual choke on my 110 now because I have it set up so I can pull the choke out a little to the "fast idle" position for winching etc.
edelbrock, manual
Weber carb 34 ICH manual choke for series IIA and III aka rover For Sale - Parts 0 December 13th, 2011 11:25 PM
Manual to Automatic Transmission Conversion FlaD90 Defender Technical Discussions 0 November 25th, 2008 07:57 AM
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
cost of parts to convert manual to automatic transmission mgrgpg Misc. Chit-Chat 9 September 15th, 2006 09:15 PM
