ECU relocation 94 D90 - Defender Source
Old July 13th, 2007, 12:27 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Talking ECU relocation 94 D90
been brain storming an idea for a while now for relocating the ecu on the D90 that i have to a higher location. Two ideas i have come up with is: one, just undoing it from where it is now and placing it to the bulkhead in front of the gearshift. two, would be using a section of the harness from a disco that has the same type of ecu therefore lengthing the cable to be able to place say on the back of the center console or the like.
would appreciate any input from members of the community.
Old July 13th, 2007, 12:44 PM
Mine is screwed to the side of the trans tunnel, which is better than the outside of the footwell. My truck has AC, so its not in the factory location anyway. I'm not sure how you could mount it to the firewall in front of the gear shift - the fuse box is right there and the lower dash is actually an air plenum.
Old July 13th, 2007, 10:01 PM
huck1974's Avatar
huck1974
shane cates
94 d90
I take it that this is for water? Why not waterproof it and leave it?
Old July 13th, 2007, 11:55 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Not sure what this would buy you...what about the distributor and alternator and the rest of the electronic stuff?
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old July 15th, 2007, 12:59 PM
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
Mine is located in the Tuffy Box in the center console.
The wiring runs through a waterproof wrapped cable on the outside of the trans tunnel on the passenger side.
The previous owner paid the LR dealer an arm and leg to do this. The distributor and alternater are waterproof (or waterproofed) models.
It can be done.
DJ
nashvillerover@comcast.net
2006 LR3
94 D-90
93 Range Rover Classic
64 Series IIA (right hand drive)
Old July 15th, 2007, 02:04 PM
Where is the stock location on a '94? I just removed my A/C and it looks like I could move it slightly higher up under the passenger foot area next to the fuses. Is that where is usually goes?
Old July 17th, 2007, 08:54 PM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
I know at one time I had seen a set of ECU extension wires for sale through a distributor. If anyone knows who it was that would be great then you could do as stated above and move it into the tuffy box. Scorpion Racing also sells a "waterproofing kit" for v8 defenders. May be worth a look.
Old July 17th, 2007, 10:00 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I actually had a UK website bookmarked a while ago that had an extended cable for the ECU for sale. it was something like 6 feet long or something outrageous. the one end plugs into the old wire and the new end into the ECU. let me see if i can find that website again because I'm going to need to move my ECU to higher grounds too.
Old July 17th, 2007, 10:25 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Charles, stock 94 w/o AC is on the front of the passenger side footwell about 3/4 of the way up.
Old July 20th, 2007, 10:36 PM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
Any luck finding those extended ecu cables? I've searched and I can't find them.
Old July 21st, 2007, 12:13 AM
huck1974's Avatar
huck1974
shane cates
94 d90
why move it? to waterproof it somewhere else?
Old July 21st, 2007, 08:31 PM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
If I move it into the headliner flooding is a slim possibility.
Old July 21st, 2007, 11:14 PM
ini88's Avatar
ini88
Daniel Marcello
haha, you will drown before the ECU does!
Old July 22nd, 2007, 12:12 AM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
can't you just get a small pelican case and drill some holes, then seal it up and stick it back?
Old July 22nd, 2007, 01:58 AM
ini88's Avatar
ini88
Daniel Marcello
Pelican, Aquapac or Fuerte Case
http://pelican.com/case_category.php...e=Micro%&New=%
http://www.aquapac.net/usstore/erol.html
http://www.fuertecases.com/Merchant2...Code=Otter-Box
The Aquapac looks nice because you can cut a hole in it easy for the cable and seal it up with some glue or something. plus the all clear plastic is nice to read those codes it spits out every other week
Old December 11th, 2010, 10:01 AM
has anyone done the ECU in the pelican case route?
if so pictures and what did you seal it up with -
i'm honestly considering just sealing up the whole box with fiberglass and silicone seal the cable thoughs with silicone.
but doing it in a pelican case would be interesting but in reality you have to do both boxes (driver and passanger)
95' D90 - daily driver..
Old December 11th, 2010, 10:17 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Slade did in his 130.
Old December 11th, 2010, 01:44 PM
airbornrover
William Skidmore
SIII 109 SW
I totally forgot about creating this thread, wow. I know the guy over at Lucky 8 sells somekind of box/kit for waterproofing, submarine style looking from the vid.
90, d90, ecu
'94 d90 turn signal relocation ECR TravelerBT Defender Technical Discussions 9 December 8th, 2008 08:25 PM
94, AA Yellow D90 Zimbo76 For Sale - Vehicles 9 October 27th, 2004 10:39 AM
Radio/CD relocation 1997 D90 ronward Defender Technical Discussions 1 February 9th, 2004 01:02 AM
Disco ECU works on D90? artm Defender Technical Discussions 3 November 27th, 2003 11:45 PM
» Defender Registry
Maggie
rankar
Hilda
badvibes
Add your Defender
