ECU Question - Defender Source
Old June 15th, 2005, 09:23 AM
dbwitt's Avatar
dbwitt
Darrin Witt
1995 Defender 90
ECU Question
I checked the previous threads and did not see an answer to my question. This should be an easy one for most of you folks out there. When installing an ECU in a 4.0 litre engine do you need to have it programed in any way by the dealership or do you plug it in and drive away? I have one that is not functioning and the dealership wanted 2500 hundred dollars. I got one for 600.00 hundred bucks. But the dealership guys tell me they need to program it. I thought it came programed to work on the 4.0 already? Any help would be appreciated.
Old June 15th, 2005, 09:33 AM
Where did you buy it from? I would think the ECU should be all set unless it was running a different engine (like a 4.6). I am not 100% on the 97's ECUs but I thought it was just plug it in and go.
Old June 15th, 2005, 11:19 AM
artm
Arthur Maravelis
97 SW
I think the ECU has to be matched to the vehicle anti-theft/immobilization "computer". You connect them to Rovacom and it programs them to recognize each other. Then you have a "legitimate" combo.
Old June 15th, 2005, 06:54 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
95 -- humm. I put a 95 disco ecu in my 93 and it works like a bomb.
Just plug it in and run it. If it's a near year, can't hurt a thing, imho. I bought mine from RoverLandParts in FL for $250.
DW
Old June 16th, 2005, 08:22 AM
OK I am a little confused, is this for a 4.0 or a 3.9? If it's a 3.9 then what Doug said is right they are plug and go. If it is a 97 then it may not be as simple.
Old June 16th, 2005, 08:32 AM
dbwitt's Avatar
dbwitt
Darrin Witt
1995 Defender 90
It is for a 4.0. The dealership says they need to program it. 3.9 is plug and play. The dealership here in Charleston, SC is not a total rip off-most of the time.
Old June 16th, 2005, 10:27 AM
artm
Arthur Maravelis
97 SW
It's for the '97 only. There's a black box behind the gauge cluster I believe that needs to be told that there's a new ECU installed. Otherwise they won't work together. It's some kind of security feature.
Old June 16th, 2005, 04:34 PM
scoloco's Avatar
scoloco
'94 D90 ST
Wow, those 3.9s do actually have an advantage over the 4.0/4.6
Old June 17th, 2005, 06:49 AM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
I had a problem with my check engine light and my speed sensors, I thought it may be a bad ECU. David M. was selling his a while back so I bought it. I just swapped them out, no problems at all. It didn't solve my check engine problem but it was not because of the ECU. If you ask me you can just swap them.
Old June 17th, 2005, 11:13 PM
Doug's Avatar
Doug
Doug Walker
Any 14CUX can be swapped with another 14CUX, imho. They are the same, whether from a Triumph or Jag or Land Rover. I believe the 93 thru 95s all had either a 14CU (93) or 14CUX. Says what it is on the box. The 14 CUX can be swapped for a 14CU but not the other way around.
So says RPI (www.v8engines.com).
Doug W.
Old June 17th, 2005, 11:44 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
you said '95? Do you have the serpentine belt with distributor? Or Distributorless?
Your ECU is under the passenger seat I believe, correct? Does it have a model number on it? As mentioned above 14CUX would be the distributor style ECU. The distributorless type does need to be programmed IIRC.
-Hans
My oil line fix
My 100k stopped odometer fix
ecu
R-380 to Auto, connecting to ECU question btate Defender Technical Discussions 0 August 25th, 2008 04:59 PM
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Where did you put your ECU jcasteel Defender Technical Discussions 6 January 12th, 2005 11:31 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
