ECU location on 95 D90? - Defender Source
Old July 18th, 2009, 10:12 AM
instantbenjamin
Benjamin White
95 NAS Defender 90 #2925
Just got my D90 and my first problem
My check engine light is on in my D90 and need to get it off to pass inspection. I've read all the threads about resetting it, but I can't figure out from any of them ...
WHERE IS THE ECU LOCATED AND HOW DO I UNPLUG IT TO RESET IT?
I did get the passenger seat off and found the diagnostic display reading fault code "44" which I read is Lambda sensor A - left bank.
The next prescribed step is to reset the ECU and see if the error code is a "fluke" etc ... but for life of me can't figure it out?
Related note, is there a go to D90 workshop manual that you guys recommend so I have a reference on locations of all the uniquely Land Rover parts?
Ben
Old July 18th, 2009, 12:31 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Under the passenger seat
Disconnect the battery wait 30 seconds then reconnect, that will reset the codes. the battery is under the drivers. Congrats on the truck
Old July 18th, 2009, 02:23 PM
instantbenjamin
Benjamin White
ECU location?
Thanks for your help.
I attached a snap of my under passenger seat setup ... looks like may be some hackery in there?
Is the ECU the large black square in the bottom of the pic?
Now that I look closer it does look like it has a large connector (about 3") of some sort attached to the black box underneath the new aluminum duct work in there (what is that btw?) ...
Do I need to disconnect that large black connector? There is some sort of tabs holding it in place. I tried the logical pinches and twists, but not sure how the tabs work. Any advice?
Ben
Success! I reset the ECU and check engine light is off. Now on to the inspection!
So, that was the ECU and connector under passenger seat. Thanks you.
It's a very nondescript black box and in my case connector was hidden by the duct work.
I attached a photo and labelled it for future reference so people with the same problem can see what's what.
Thanks again
Ben
ID:	20610   Click image for larger version
Old July 18th, 2009, 04:03 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Ben,
It looks like you have some sort of heater for the back seats in there. That is not a standard piece and I would guess there is a switch somewhere that controls it.
I have a workshop manual that you can have, shoot me a PM if you want it.
Greg
Old July 18th, 2009, 05:25 PM
That is the genuine aux. heater.
Next time just unplug the battery and wait a while. Same effect as unplugging the ECU.
Ron
90, 95, d90, ecu
D90 TD5 ECU Chip upgrade? Should I or not? adibitar Defender Technical Discussions 11 September 1st, 2005 01:22 AM
'95 Yellow D90 ST w/ 3 tops dalesmith71 For Sale - Vehicles 10 March 19th, 2004 09:59 AM
Diagnostic Plug on 95 D90 SW? Troys Defender Technical Discussions 5 March 13th, 2004 03:49 PM
FS: Four SW Jump Seats from 95 D90 DJ Menasco For Sale - Parts 4 December 19th, 2003 12:28 AM
Disco ECU works on D90? artm Defender Technical Discussions 3 November 27th, 2003 11:45 PM
